Sony TA-N86 Power Amplifier
Sony TA-N86 Power Amplifier  Empty Sony TA-N86 Power Amplifier
Post by cliffwong90 Tue Dec 07, 2021 4:10 pm
Selling of Sony TA-N86 Power Amplifier. Whatsapp if interested!
PLEASE READ THE DESCRIPTION, BEFORE COMMENTING ANYTHING. PRICE WILL BE STATED HERE. PERSONALLY WHATSAPP ME IF INTERESTED IN BUYING OR YOU HAVE ANY QUESTIONS. BRIEF DESCRIPTION OF THE SPEAKERS WILL BE WRITTEN HERE.
Description:
The TA-N86 power amplifier is a powerful and technically advanced audio amplifier offering superior performance.
Each stage of the TA-N86 employs a DC amplifier, and by using matched pairs of transistors, a considerably better temperature characteristic and stable operating point under all signal conditions is obtained.
The differential amplifier uses no coupling capacitors and is well suited for the amplification of low frequencies.
Pulse techniques are utilized in the power supply section, which by reducing the weight of the power supply components, contribute to an overall weight reduction, as well as furnishing a highly regulated power source under all conditions of signal input or line voltage fluctuation.
The TA-N86 employs a newly-developed Hi-fT transistor with excellent linearity at high frequencies and high current levels. This transistor greatly reduces switching distortion at high frequencies.
In addition, the TA-N86 includes a three-stage differential amplifier in the voltage-amplifier section, and a three-stage Darlington configuration in the power-amplifier section all of which aid in providing superior distortion characteristics.
Each circuit of the right and left channels in individually laid out. This contributes to the excellent channel separation.
The TA-N86 can be operated as a class A amplifier, a class B amplifier, or a mono amplifier by means of the Operation Switch.
Specifications:
Power output: 80 watts per channel into 8Ω (stereo), 180 watts into 8Ω (mono)
Frequency response: 1Hz to 200kHz
Total harmonic distortion: 0.007%
Damping factor: 70
Gain: 27.4 dB
Input sensitivity: 1.1V
Signal to noise ratio: 120dB
Dimensions: 480 x 80 x 380mm
Weight: 8kg
Finish: silver front panel
Condition: 9/10
Price: RM 3300 (Negotiable)
Whatsapp: +6012-9987990/+6016422-1082
(Click Images to View Full Picture)
Sony TA-N86 Power Amplifier  Whatsa55
Sony TA-N86 Power Amplifier  Whatsa56
Sony TA-N86 Power Amplifier  Whatsa57
Sony TA-N86 Power Amplifier  Whatsa58
Sony TA-N86 Power Amplifier  Whatsa59
cliffwong90
Number of posts : 284
Sony TA-N86 Power Amplifier  Empty Re: Sony TA-N86 Power Amplifier
Post by cliffwong90 Fri Dec 17, 2021 3:15 pm
cliffwong90
Post by cliffwong90 Tue Jan 04, 2022 9:42 pm
cliffwong90
Post by cliffwong90 Fri May 13, 2022 12:08 pm
cliffwong90
