Densen Audio Technologies DP-Drive Phono Stage - With DP-01 MM DP-02 MC
Item: Densen Audio Technologies DP-Drive Phono Stage - With DP-01 MM DP-02 MC
Uses the unique light-driven LED Optical Power Supply design to ensure a zero noise floor. A lot of MC performance for this budget……..
It is said to be one of the quietest phono preamps in the world!
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes with original Densen power supply. Black aluminium chasis.
Price: RM1750 or swap/topup
Can Trade-In your Amplifier/
DENSEN DP 01
€ 300.00
The DP-01 is an MM card to be inserted inside the Densen DP-Drive . It is also compatible with older models of integrated and preamplifiers such as: B-100, B-200, DM-10 and DM-20.
Despite the truly affordable price, the DP-01 is a very high quality RIAA Phono card.
The advanced design and extreme neutrality make it compatible with all MM (and high output MC) cartridges available on the market
Densen DP-01 Specifications:
Frequency response: 20 to 20,000Hz
Signal to noise ratio: 85dB
Input impedance: 47K ohms
Input capacity: 100pF
Channel separation: 90dB
https://www.audioemotion.co.uk/densen-dp-drive-phono-stage-981-p.asp
https://www.soundstagehifi.com/index.php/equipment-reviews/489-densen-audio-technologies-dp-drive-phono-stage
https://webshop.densen.dk/products/dp-drive
https://www.perfectaudiosrl.it/prodotto/densen-dp-01/
https://usato.audiograffiti.com/annunci/pre-phono/198012/
https://www.garosihifi.it/prodotto/densen-dp-02-mc/
https://shop.soundgallery.gr/products/used-/-demo/proenischytes-1/densen-dp-drive-/-dp-02-mc.html
DENSEN DP 01
€ 300.00
» Densen Audio Technologies DP-Drive Phono Stage - With DP-01 MM DP-02 MC
» Densen DP Drive Equipped with DP-02 MC Phono Stage (Sold)
» Densen Phono Preamp - DP Drive DP 02 - MC (Used)
» Densen Audio Technologies B150+ Integrated Amplifier (USED)
» Audio Note M1 phono stage (Used)
