Teac CD-P650 CD Player
Teac CD-P650 CD Player Empty Teac CD-P650 CD Player
Post by raymond88 Sat Jan 08, 2022 2:13 pm
Item: Teac CD-P650 CD Player
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes with original remote control and original box.
Price: RM1250 or swap/topup
Can Trade-In your Amplifier/
Retail Price is RM1999.00
Teac CD-P650 CD Player Teac411
The full-featured CD-P650 from TEAC combines a CD player, with USB and iPod playback for a variety of playback in one component. It plays standard CDs as well as MP3 discs, allowing hours of playback from a single disc. The front panel buttons navigate through subfolders to find your music. Music is converted through a high-quality Burr Brown 1791ADBR with 192kHz/24-bit resolution. Compact discs are clamped onto a center-mounted drive mechanism for minimal vibration, reducing jitter distortion for clearer sound.
Main features
Record to USB flash drive
The CD-P650 includes a feature to record audio CDs to USB flash drive in MP3 file format. This lets you transfer audio CDs to MP3 files easily, with no need for a PC. Users can select between 1x and 2x recording speeds and set MP3 file recording bit rates from 64, 96, 128, and 192 kbps to meet the needs of virtually any recording requirements.
iPod digital audio output feature
Users can connect the digital audio output from an iPod to digital input devices (including D/A converters and AV amplifiers) to enjoy higher quality audio than possible with conventional analog connections. Output uses PCM format (44.1 kHz/16 bit) for compatibility with most digital input devices.
PCM1791A Burr Brown DAC
The CD-P650 uses the PCM1791A Burr Brown D/A converter, renowned for its fidelity, faithful audio reproduction, and excellent THD+N and dynamic range characteristics. The PCM1791A also plays a major role in rendering acoustic and soundstage characteristics
Center mechanism construction
The CD mechanical drive is center-mounted to balance the unit's weight and minimize vibration and resonance during playback.
Features:
Function: CD, USB/iPod
Supports CD, CD-R/RW and MP3 Disc
USB Port for iPod Digital Interface and USB Memory Rec/Play
Digital Audio Connection from iPod via USB Docking Cable (not included)
iPod/iPhone Charging while Playback
MP3 Recording from CD to USB Memory Device
MP3 Playback from USB Memory Device
Compatible with Most MP3 Players and USB Flash Memory
Burr Brown 1791ADBR, 24-bit/192kHz Sampling, Advanced Segment, Audio Stereo Digital-to-Analogue Converter
Refined Audio Circuits
Repeat (One, All, A-B), Shuffle, 32-track Program Play
Multi-function FL Display
1/4" Headphone Jack with Level Control
Remote Control Included
Optional iPod Cradle (DS-7)
Specifications (CD Player):
Frequency Response: 20-20kHz (±2dB)
THD: less than 0.005kHz (1kHz)
S/N Ratio: more than 100dB
Analogue Output: 2.0Vms (RCA)
Analog Audio Out: x 1 (RCA, Gold-plated)
Digital Audio Out: x 1 (TOS-link Optical)
Specifications (USB section):
Frequency Response: 20-20kHz (Playback)
20-15kHz (Recording)
S/N Ratio: more than 85dB (Playback/Recording)
USB Power Supply: 5V DC, 0.5A
Headphone: x 1 (1/4")
USB Port: x 1
Operation: 120V AC, 60Hz (US)
Dimension (W x H x D): 17-1/8" x 3-3/8" x 11-1/4" (435 x 85 x 285 mm)
Weight: 8 lbs. 13 oz. (4.0kg)
Teac CD-P650 CD Player Teac112
Teac CD-P650 CD Player Teac212
Teac CD-P650 CD Player Teac312
Number of posts : 8675
Teac CD-P650 CD Player Empty Re: Teac CD-P650 CD Player
Post by raymond88 Sun Jan 16, 2022 5:44 pm
Post by raymond88 Sun Jan 23, 2022 10:09 pm
Post by raymond88 Sun Jan 30, 2022 4:49 pm
