Musical Fidelity Encore 225 Integrated Amplifier Made In England(PL)
Musical Fidelity Encore 225 Integrated Amplifier Made In England(PL) Used In Excellent Condition Now Selling At RM10,750. Free Shipping Within West Malaysia.
The Encore 225 is a complete audio solution allowing you to keep all your music in one place. It accepts almost any conceivable analog or digital audio source. It is also compatible with many network speakers, such as Sonos. There is a very clear, large, high resolution full colour display so you can see what’s going on.
Features:
TECHNICAL SPECIFICATIONS
Type: Streaming, all-in-one ripping CD player/amplifier
Analogue Inputs: 3 × Line Level RCA 300mV nominal 2V typical up to 7V rms
Digital inputs: 2 × optical S/PDIF 24 bit inputs up to 192kHz, 2 × coax S/PDIF 24 bit inputs up to 192kHz, 1 × USB 3.0 type ‘A’ connector, 1 xUSB 3.0 type “B” connector (for future expansion), 3 × USB2.0 type ‘A’ connector (1 front, 2 rear), 10/100/1000 Base-T Ethernet connector
Outputs: 1× line level fixed 2.0V @ 0dBFS (300mV rms nominal, >6V rms max), 1× line level preamp variable outputs (>6V rms max) (Preamp gain, line input to preamp outputs is 4.5x (13dB) at maximum volume), Headphone output suitable for headphones impedance 8 ohms to ∞. (Headphone output features independent volume setting)
Digital precision: 1× optical S/PDIF 24-bit output up to 192kHz, 1× coax S/PDIF 24-bit output up to 192kHz
Speaker outputs: 1 pair 4mm banana plugs per channel
Power output: 225 Watts per channel into 8 Ohms
THD (+ noise): < 0.007 % typical 20Hz–20 kHz
Signal to Noise Ratio: >107dB ‘A’ – weighted
Frequency Response: +0, –0.1dB, 10Hz to 20 kHz
Internal storage: 2.5” 1 TB SATA II hard disk (included) or SSD (future upgradeable)
Dimensions W×H×D: 44 × 12.5 × 40cm
Weight: 23 kg
www.stylelaser.com.my
Features:
- Easy and intuitive to use
- Huge connectivity
- Upgradeable 1TB internal storage for over 2500 CDs (bit perfect ripping from CD drive)
- Power amplifiers are the same as those in the M6si
- Compatible with many network speakers, such as Sonos
- Large, high resolution, full colour display
- Control with either IR handset or Apps ( both Apple and Android)
- Dual core 64bit Intel CPU - as future proof as we can make it
- 32 Bit 384k DAC
Weight: 23 kg
- Number of posts : 922
jamalnor likes this post
» Musical Fidelity Elektra E100 Integrated Amplifier & Musical Fidelity Elektra E600 CD Player Made In England (Used)
» Musical Fidelity F22 Pre Amplifier + Musical Fidelity F15 Power Amplifier Made in England ( PL )
» Musical Fidelity 3A Pre-Amplifier, Made in England used
» Musical Fidelity A3 (Made in England) 24-Bit CD Player (Used)
