Roksan K3 Power Amplifier -Made in England
A very fine sounding 140Watts+ Roksan K3 Power Amplifier. The K3 Power Amplifier is a high performance and powerful solution for taking your system to the next level.
With XLR (Balance) And RCA input stage built in.
Amp in very good working condition (First hand owner). Amazing amplifier Roksan K3 150w a British legend.
Key Features
Symmetrical amplifier layout
Optimised power supply layout, distribution and decoupling
Decoupling and power regulation to all stages
Directly powered power amp section
Optimised routing and short speaker output cables
Balanced XLR and single-ended RCA inputs and output
0.5W standby operation with auto detect and a 30 minute standby timer
SPECIFICATIONS
Amplifier Type : class-AB
Input: RCA, XLR
Input Impedance : 23 kohms
Input Sensitivity (115 W) - 900 mV
Outputs Speaker :(L & R)
Power Output (Per Channel) : > 140 W (8 ohms) / > 220 W (4 ohms)
Power Supply : 500 VA Ultra low noise toroidal transformer
Damping Factor: >110 (8 ohms)
Frequency Response : <3 Hz - >100 kHz (-3 dB)
Gain: 31.6 dB
Harmonic Distortion: <0.003 % 1 kHz - 8 ohms
Power Consumption: Warm up mode <25 W, Full Power <800 W
Signal to Noise Ratio: 100 dB (ref. 900 mV)
Dimensions (W x H x D): 432 x 105 x 380 mm
Weight: 13 kg
https://www.roksan.com/en/product-ranges/k3/k3-power-amplifier/
COD in PJ only , Rm5500
Interested: WhatsApp 012-3889665(Leong)
Thank You
Key Features
SPECIFICATIONS
Input: RCA, XLR
Gain: 31.6 dB
Weight: 13 kg
Thank You
Last edited by pleong on Wed Apr 06, 2022 9:02 am; edited 1 time in total (Reason for editing : reprice)
pleong- Frequent Contributor
- Number of posts : 164
Registration date : 2018-01-29
» Roksan K3 Power Amplifier Made In England
» Roksan Kandy K2 Power Amp (Made in England)
» Roksan Caspian M2 Integrated Amplifier Made In England
» Onix OA1200 Power Amplifier - Made In England
» QUAD 405 Class A Power Amplifier (made in England) (Sold)
