Jeff Rowland 102S Power Amplifier Made in USA (PL)
Jeff Rowland 102S Power Amplifier Made in USA (PL) Used In Excellent Condition Now Selling At RM5,650. Free Shipping Within West Malaysia.
Output Power, Continuous RMS 100 watts @ 8 ohms, 200 watts @ 4 ohms per channel
Frequency Response 5 Hz – 65 kHz, -3 dB @ 8 ohms
Peak Output Current 11 amps
Dynamic Range 110 dBa
Load Impedance Range 3 ohms – 16 ohms
Input Impedance 48k ohms
THD + Noise, 0.1 watts – 200 watts, 4 ohms < 0.2%, Typically .02% @ 1 kHz
CCIF Intermodulation Distortion, 14/15 kHz < .0005%, 10 watts, 4 ohms
Damping Factor @ 1 kHz > 1000
Overall Gain (Balanced or Unbalanced) 27 dB
Common Mode Rejection Ratio > 85 dB, 20 Hz – 20 kHz
Absolute Phase Non-inverting, Pin 2 Positive
Inputs 1 Balanced (XLR) per channel
(Unbalanced operation requires an optional XLR to RCA adapter)
Outputs 1 CE-Approved Speaker Wire Clamp per channel
Power Consumption Idle – 10 watts, Maximum – 500 watts
Amplifier Weight 7.4 lbs. / 3.4 kg
Overall Amplifier Dimensions (H) x (W) x (D)
2.9” x 13.7” x 7.3”
74mm x 348mm x 185mm
www.stylelaser.com.my
Jeff Rowland 102S
Features- One pair XLR input connectors for balanced system configurations. Same gain and input impedance characteristics are ensured whether
- XLR or RCA adapted inputs are used.
- CE approved speaker output terminals require no tools for secure, low resistance connections.
- Fully-balanced topology implemented in both input and output circuitry.
- Low noise, high-current, switchmode power supply provides highest performance at any world-wide mains operating voltage and ensures
- consistent performance under all operating and AC line conditions.
- Fully-balanced inputs provide universal compatibility with other components and eliminate ground loop noise and EMI.
- High efficiency ICEpower
power conversion technology generates high output power with very little heat, promotes long component life and permits a relatively small physical size.
- Low power consumption permits constant power-up operation to eliminate warm-up time.
- Ultra-low resonance, structurally rigid chassis, precision-machined from a solid block of aircraft grade 6061-T6 aluminum.
- Remote ON/OFF input jack allows amplifier standby operation from a remote source for inclusion into home theater (A/V) systems.
2.9” x 13.7” x 7.3”
- Number of posts : 959
» Jeff Rowland PC-1 external power supply /conditioner for Capri S2 pre amp /102s/201/501(used)
» Jeff Rowland 8 Power Amplifier
» Jeff Rowland Model 625 power amplifier (Sold)
» Jeff Rowland Model 102 S Stereo Power Amplifier (Used)
» Jeff Rowland 112 power amp
