Thiel PCS monitor bookshelf speaker
2 posters
Description: Three-way, stand-mounted, reflex-loaded loudspeaker. Drive-units (all anodized aluminum): 1" (25mm) dome tweeter coaxially mounted in 4" (76mm) cone midrange; 6.5" (165mm) cone woofer. Bandwidth: 55Hz-23kHz, -3dB. Frequency response: 57Hz-18kHz, ±2dB. Phase response: ±10 degrees, minimum. Sensitivity: 87dB/2.83V/m. Impedance: 4 ohms nominal, 3.3 ohms minimum. Recommended power: 50-200W.
Dimensions: 19" (483mm) H by 7.25" (185mm) W by 11.5" (292mm) D. Weight: 30 lbs (13.6kg) each.
Hi there , Thiel model PCS monitor bookshelf speaker 1 pair
Together solidsteel stand want to let go.thanks to viewing.
Condition 8.8/10
Asking rm 4000
If interesting can WhatsApp
0167638594
yphai- New Member
- Number of posts : 22
Registration date : 2009-06-01
jdgobio likes this post
yphai- New Member
Re: Thiel PCS monitor bookshelf speaker
you may only bump once very seven days please.
moderator
moderator
bal- Moderator
- Number of posts : 1258
Speakers: maggie 1.7
yphai- New Member
yphai- New Member
yphai- New Member
yphai- New Member
yphai- New Member
» Monitor Audio Monitor Gold 7 Bookshelf Speaker (Sold)
» Monitor Audio Monitor 7 Gold Bookshelf Speaker
» (WTS) Monitor Audio BR2 bookshelf speaker(used)
» Monitor Audio Monitor 50 Bookshelf Speaker
» Monitor Bookshelf Speaker
