Magnat Monitor Supreme r 302A 12' Subwoofe (Used)
Construction: active with front output and bass reflex
Speaker: 12" (300mm)
Amplifier power: 100W RMS/220W peak
Frequency range: 16-200Hz
Crossover frequency: 50-150Hz, adjustable
Automatic on/off
Standby power consumption: <0.5W
Dimensions: 355 x 440 x 395mm (WxHxD)
Weight: 16kg
Magnat Monitor Supreme Sub 302A Mocca
The Magnat Monitor Supreme Sub 302A subwoofer features a customisedamplifier specially adapted for optimal low-frequency performance. Itsspeaker was carefully tuned using. It is placedinside a sturdy metal basket that connects the speakerto a powerful magnet. It usescellulose hardenedpaper membranes. The rubber feet minimise vibrations transmitted to the underlying surface.
The dome is made and coated with a high quality decorative foil, and compared to the first series, this modelhas elegant rounded edges. Due to improvements in the
basreflex horns have achieved a topquality design, so it now minimises the effect of airflow on the sound and at the same time itdiffuses deep frequencies in the room better. On the rear sideof the subwoofer there is a "Standby" switch for. There are also low-level inputs, outputs, and high-level inputs.
Conditions: 8/10 (USED)
Price: RM950 inclusive postage to West Malaysia
- Number of posts : 4237
» [Price reduced] Magnat Multi Monitor 220 Active Speakers
» Magnat LZR 580 New headphone
» Sold Magnat MA600 Hybrid Integrated Amplifier with DAC
» Magnat RV-3 integrated amplifier (Used)
» Ortofon MC 30 supreme (used)
