PSA AUDIO V1800 18inch Subwoofer(sold)
DRIVER
AMPLIFIER SPECIFICATION
CONDITION:8/10
PRICE:SOLD
FOR MORE INFO PLEASE CALL OR WHATAPPS
018-9742567 YANG
016-5368723 YUAN
- Power Sound Audio proprietary 18” driver
- Extended and vented pole geometry
- Vented back plate to maximize air flow
- Extremely linear and dynamic motor system
- Epoxy reinforced cone neck/apex joint
- Concentric foam surround, treated for longevity
- Highly treated, rigid paper cone body
- Die-cast rigid aluminum frame
- Three inch diameter, four layer copper voice coil wound on a rigid multi-layer aluminum former with Kapton heat shielding
- Fatigue limiting designed, silver alloy lead wires
- Single poly cotton semi-progressive, high excursion spider
- Paper outer dust cap with acrylic coating
- Inner Mass Loading Cap that also strengthens the cone body
- Assembled in the USA
- ICEpower
audio technology
- Amplifier Power: 725 watts
- Inputs: Left and Right RCA inputs
- On, Auto, Off selector
- Gain control
- Time delay(phase) control
- Crossover control
- Room size control
- Custom DSP(digital signal processing) enables superior engineering refinement
- CE and FCC approved; EMC and safety pre-approved
- Fully integrated amplifier and power supply with mains-converter and auxiliary-converter
- Patented HCOM modulation and control techniques for unparalleled audio accuracy
- Sound optimized soft clipping
- Soft start power up with mute/de-mute.
- Thermal and over-current protection
- Standby converter with low standby power consumption (less than 1 watt)
- Universal mains operation (100-240 V, 50-60 Hz)
- Standby power consumption 170 mW @ 230 V
- ErP (1275/2008/EC) compliant
- Energy Star
v3.0 compliant
- 117 dBA dynamic range
- THD+N = 0.005 % @ 1 W (4 Ω, 1 kHz)
- THD+N = 0.0008 % @ 50 W (4 Ω, 100 Hz)
- CCIF IM distortion = 0.0003 %, 10 W, 4 Ω, 18.5 kHz / 1 kHz
- High output current limit of 30 A
CONDITION:8/10
PRICE:SOLD
018-9742567 YANG
016-5368723 YUAN
YUAN- Club Member
- Number of posts : 41
» Yamaha RX-V1800 AV amp (SOLD)
» Yamaha RX-V1800 AVR (SOLD)
» Yamaha RX-V1800 DTS-HD AV Receiver [SOLD]
» SOLD Yamaha RX-V1800 AV receiver (130W/channel)
» Audio Pro Sub+ Mk2 Subwoofer (used) -SOLD
