ProAc Response D15 Floorstand Speakers in Yew Wood Finish
ProAc Response D15 Floorstand Speakers in Yew Wood Finish Empty ProAc Response D15 Floorstand Speakers in Yew Wood Finish
Post by raymond88 Tue Apr 26, 2022 5:38 pm
Item: ProAc Response D15 Floorstand Speakers in Yew Wood Finish
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes with original speaker grills and spikes.
Price: RM6250 or swap/topup
Can Trade-In your Amplifier/
ProAc Response D15 Floorstand Speakers in Yew Wood Finish Proacd12
ProAc Response D15 Floorstand Speakers in Yew Wood Finish Proacd13
ProAc Response D15 Floorstand Speakers in Yew Wood Finish Proacd14
ProAc Response D15 Floorstand Speakers in Yew Wood Finish Proacd15
ProAc Response D15 Floorstand Speakers in Yew Wood Finish Proacd16
Description :
With its roots in the highly acclaimed Response One Point Five, this elegant new model delivers a heightened level of dynamic performance, adding greater weight and a lively muscularity to the musical experience. At the hub of this improvement is Proac's own new 61/2" bass/midrange unit. This driver has a radical new basket design for higher rigidity and a completely reworked magnet and coil assembly. Bass loading is achieved through a system which has never been used before in a Response range model. As a result this driver excels in areas of control, power handling, openness and midrange detail. Through a sophisticated crossover network the bass/midrange driver is harnessed to the famous ProAc 3/4" soft dome tweeter, which has become renowned for its smooth, sweet and detailed sound. As ever, Response range build quality is outstanding. Finished in real wood veneers, these superb cabinets are built to look good for a long time. The new D15 is a remarkable fulfillment of the promise of cutting edge technology, producing a powerful yet refined presentation of music out of all proportion to the size of the cabinets. These are floorstanders with a beguiling musicality which will satisfy the most demanding of audiophiles.
Specifications :
Nominal Impedance......................8 ohm
Recommended Power...................20w ~ 180w
Frequency Response....................30Hz ~ 30kHz
Sensitivity(1w @ 1m)....................88dB
Bass/Midrange.............................Driver 6 1/2" diameter unit with new rigid chassis, linear
                      .............................motor assembly and large copper magnet and phase plug.
                      .............................Glass fibre weave cone exclusive to ProAc
Tweeter........................................3/4" soft dome exclusive to ProAc with special honeycomb wound voice
           ........................................coil and rear chamber damping
Crossover.....................................Finest components on dedicated circuit board. Multistrand oxygen-free
              .....................................copper cable throughout. Split for optional bi-wiring and bi-amping.
Grille...........................................Acoustically transparent crimplene
Finish..........................................Cherry
Dimensions(w x d x h)..................190 x 254 x 984mm per side
Weight.........................................50lbs/23kg per side
http://www.listeninn.com/product/407001-10877/Loudspeaker/Floorstanding-Speakers/Proac-Response-D15
Number of posts : 8138
