Pre and Power Amplifier
The Accuphase P-300 was a highest grade stereo power amplifier which forms a perfect combination with the highly regarded C-200 Control Center.
The P-300 employs MOSFETs (Metal Oxide Semiconductor FETs), considered the most promising active device for power amplifier applications, in a triple push-pull output stage that delivers the high power of 200 watts per channel.
One of the main features of the P-300 is that the advantages of minimum distortion offered by pure Class-A amplifier operation can be enjoyed by switch control.
Class-A operation offers a higher degree of perfection in amplification characteristics, especially in the high frequency range. In addition, the use of MOSFETs in the P-300 ensures a complete absence of notching distortion.
- Power output: 200 watts per channel into 8Ω (stereo)
- Frequency response: 20Hz to 20kHz
- Total harmonic distortion: 0.01%
- Damping factor: 150
- Input sensitivity: 1.6V
- Signal to noise ratio: 120dB
- Semiconductors: 34 x transistors, 20 x FET, 6 x IC, 54 x diodes
- Dimensions: 445 x 160 x 455mm
- Weight: 31.2kg
- Local Voltage
Accuphase Precision Control Center C-300 is a Pre Amplifier
- Total harmonic distortion: 0.005%
- Gain: 86dB (MC), 60dB (MM), 24dB (line)
- Input sensitivity: 0.1mV (MC), 2mV (MM), 126mV (line)
- Signal to noise ratio: 72dB (MC), 85dB (MM), 110dB (line)
- Output: 126mV (line), 2V (Pre out), 10V (Pre out Max)
- Semiconductors: 159 x transistors, 10 x FET, 102 x diodes
- Dimensions: 445 x 160 x 370mm
- Weight: 15kg
- Local Voltage
Selling as it is, functional test is allowed. Due to these two unit is very heavy, thus prefer self-collect, shipping also can be arranged provided buyer take own responsibility for the risk of shipping and handling condition, and pay for the shipping fees.
If buying separately the price will be as follows, but prefer to sell in pair, unless have separate buyer for the both at the same time.
Price: Sold
- Weight: 31.2kg
- Local Voltage
- Weight: 15kg
- Local Voltage
Price: Sold
Last edited by Roysberg on Mon Jun 06, 2022 10:41 am; edited 3 times in total (Reason for editing : Sold)
Roysberg- New Member
- Number of posts : 1
Registration date : 2021-07-10
» [SOLD] Sony TA-E2000ESD Digital Processing Control Amplifier (Preamplifier), Sony TA-N330ES Power Amplifier, Sony TA-N220 Power Amplifier (All Used) [SOLD]
» Gryphon DM100 dual mono Power amplifier , Tice Power Block Titan(2pcs) Power Conditional, Marant CD SA14 SACD Player, Cary DAC 200TS Tube DAC
» Harman Kardon Citation Eleven Pre-Amplifier and Twelve Power Amplifier (Sold)
» Complete Cyrus Hi-fi System: Discmaster CD Transport, Dacmaster, 'Pre' Amplifier, 'Power' Amplifier (Used)
» AudioSymphony M7L Tube Pre-Amplifier and Hybrid Stereo Power Amplifier H80S (Sold)
