Analysis Plus Oval One Audio Interconnect 1 meter pair (Used) SOLD
Analysis Plus Oval One Audio Interconnect 1 meter pair (Used) SOLD Empty Analysis Plus Oval One Audio Interconnect 1 meter pair (Used) SOLD
Post by KhimAudio Fri Jun 03, 2022 6:59 pm
For audiophiles who don’t need XLR connections, we developed the superb-value Oval One Interconnect. It uses a braided signal conductor in our proprietary hollow oval design along with a braided outer shield mated to a true 75 ohm RCA connector with a low-loss dielectric.
Because Oval One is handmade using first-rate materials, it will outperform other cables costing many times more. The 100-percent shield coverage ensures the very low noise floor that’s essential to experiencing the entire dynamic range of symphonic music.
The RCA connection is solder-less, using a compression contact technique that spares the dielectric from damage that heat from soldering can cause. This technique also eliminates the poor signal transfer that results from a cold solder joint. Our fussiness adds to the cost of the cable, but the performance increase is worth the added care.
Length: 1 meter pair
Asking: RM Sold
Interested please call or text me at: 016-3662081 Khim
Analysis Plus Oval One Audio Interconnect 1 meter pair (Used) SOLD P1070528
Analysis Plus Oval One Audio Interconnect 1 meter pair (Used) SOLD P1070529
Analysis Plus Oval One Audio Interconnect 1 meter pair (Used) SOLD P1070530
Last edited by KhimAudio on Thu Jul 21, 2022 7:53 am; edited 1 time in total (Reason for editing : Item sold. Thank you)
KhimAudio
Number of posts : 2166
