Marantz PM-17SA ver.2 Integrated Amplifier SOLD
Marantz PM-17SA ver.2 Integrated Amplifier SOLD Empty Marantz PM-17SA ver.2 Integrated Amplifier SOLD
Post by loyhifi Sat Jul 02, 2022 9:21 pm
Form Integrated Amplifier
Output power 100W+100W (4ohms)
80W+80W (6ohms)
60W+60W (8ohms)
THD (20Hz - 20kHz, both channel simultaneous drive, 8ohms) 0.01%
Cross modulation distortion (SMPTE) 0.01%
Output bandwidth (an 8-ohm load intensity, 0.04%) 10Hz - 50kHz
Frequency characteristic (compact disk, Source Direct) 5Hz-70kHz+0 -1 dB
Dumping factor (8 ohms, 20Hz - 20kHz) 100
Input sensitivity/impedance Phono MC: 230 microvolts/100 ohms
Phono man month: 2.4mV/47kohm
High SFT Level: 220mV/22kohm
Main in: 1.6V/22kohm
An Output voltage/impedance Pre out: 1.6V/250 ohm
Phono maximum permissible input (1kHz) MC:15mV
MM:150mV
RIAA deflection (20Hz - 20kHz) �}0.2dB
S/N (an IHF A network, input short-circuit) Phono MC:76dB
Phono MM:90dB
High Level:112dB
Supply voltage AC100V, 50Hz/60Hz
Weight 16.0kg
made japn
remote no
price SOLD
contact loy 0163683523
loyhifi
Number of posts : 3974
