Franco Serblin Ktema Speaker
Franco Serblin Ktema Speaker Empty Franco Serblin Ktema Speaker
Post by victorchangs76 Mon Jul 04, 2022 11:22 am
Specifications:
- Geometry: four-way topology, five units. The two low-frequency radiators are compression-loaded and room-interfaced at the lower part of the rear of the enclosure. Above the “fusion” frequency, the mid-high cardioid radiators reproduce the significant part of the spectrum, at the top section of the front of the cabinet.
- The cabinet is a rigid, triple arch-shaped structure. The two lateral front cheeks are concave, while the woofer compressor is convex.
- The tweeter is a well-established and time-proven 28mm soft-dome unit, created by Ragnar Lian, one of the greatest Danish masters of transducer design.
- The midrange array consists of two custom-made 4in units in a step-compensated baffle, in a cardioid acoustic-resistance configuration, for the most accurate reproduction of the musical perspective.
- The woofers are custom-made 9in metal cone, piston performance-optimised units, in a compression-controlled and room-interfaced configuration.
- The crossover is a mutational variable slope, coherent spatial radiation design.
- Yter pure Silver-Palladium mono-wiring used throughout.
Frequency Response: 26Hz - 33Khz, in room
Nominal Impedance: 4 ohm (minimum 3, 2 ohm at 70 Hz)
Sensitivity: 92 dB/W/m
Minimum power amplifier: 20W per channel
Dimensions: 42,5 cm × 46 cm × 111 cm  (unpacked)
                     52 cm × 57 cm × 110,5 cm  (packed)
Weight: 110 kg/pair (unpacked) - 127 kg/pair (packed)
Finishing: High gloss piano black, hand-polished aluminium top & bottom
                Satin Sycamore, hand-polished aluminium top & bottom
Limited Edition No. 022/050
Condition: 8/10 (with original carton box)
Price Asking: RM63,800.00
DM/Call : 012 3299968 Victor
Franco Serblin Ktema Speaker Ktema013
Franco Serblin Ktema Speaker Ktema012
Last edited by victorchangs76 on Thu Aug 18, 2022 11:38 pm; edited 2 times in total (Reason for editing : reduce price)
victorchangs76
Number of posts : 115
Registration date : 2016-09-22
Source(s): VPI TNT
Amplification: Vitus
Speakers: Franco Serblin Ktema
Franco Serblin Ktema Speaker Empty Re: Franco Serblin Ktema Speaker
Post by victorchangs76 Thu Jul 14, 2022 2:38 pm
victorchangs76
Source(s): VPI TNT
Post by victorchangs76 Mon Aug 08, 2022 3:23 pm
victorchangs76
Source(s): VPI TNT
Post by victorchangs76 Thu Aug 18, 2022 11:39 pm
victorchangs76
Source(s): VPI TNT
Post by victorchangs76 Sat Nov 12, 2022 9:31 pm
victorchangs76
Source(s): VPI TNT
