Mission M32 Bookshelf Speakers
Mission M32 Bookshelf Speakers Empty Mission M32 Bookshelf Speakers
Post by raymond88 Tue Aug 02, 2022 12:21 pm
Item: Mission M32 Bookshelf speakers
Condition: 8.5/10. Item is in excellent condition.
Price:  RM1000 RM850 or swap/topup
Mission M32 Bookshelf Speakers Missio42
Mission M32 Bookshelf Speakers Missio41
Mission M32 Bookshelf Speakers Missio44
Mission M32 Bookshelf Speakers Missio43
The Mission M32 is a stand-mount loudspeaker ideally suited to the Mission Stancette Stand. Similar to the M31 but with a larger 165mm DiaDrive bass unit, the Mission M32 provides deeper bass extension and impressive midrange performance. Mission's M32 speakers transmit power, excitement and emotion and excellence at an affordable price.
To match the outstanding performance of the new DiaDrive bass unit, a lightweight, Viotex fabric dome treble unit handles high frequencies up to an ultrasonic 28kHz. The true analysis of this extended bandwidth can be found in the sweetness, clarity and detail resolution that only comes from a drive unit that pushes distortion products beyond the limits of audibility.
The curved profile to the 30mm thick front baffle optimises dispersion and provides a rigid frame for the drive units in conjunction with the strongly braced 18mm MDF cabinet construction. The Mission M32 crossover high uses high quality Audiophile grade capacitors to ensure high frequency clarity and also presents an easy amplifier load suits all types of amplification. The speakers are magnetically shielded suitable for close proximity to the television.
Spec:
Frequency Response at 3dB : 52Hz to 20kHz
Sensitivity SPL/m/2.83V : 90dB
Amplifier Power Range : 25 to 100 watts
Dimensions (HxWxD) in mm : 320x200x325
Cross Over Frequency : 2.8kHz
Effective Volume : 12.4 litres
Enclosure Type : 2 way reflex loaded
Nominal Impedance : 8 ohm (min 40 ohms)
Weight : 14kgs
Number of posts : 8353
Mission M32 Bookshelf Speakers Empty Re: Mission M32 Bookshelf Speakers
Post by raymond88 Tue Aug 09, 2022 1:17 pm
