Cayin MT-12N EL84 Integrated Amplifier (SOLD)
- Four EL84s are used for class AB1 P.P amplification. This vacuum tube not only is of great speed to the music signal, but also high dynamic.
- The toroid power transformer and EI audio transformer are specially manufactured for Cayin MT-12 by applying our unique workmanship, which has low magnetic leakage, wide frequency response and low impedance.
- One 12AU7 and two 6N1s are used in the preamplifier.
- With headphone output.
- The high quality capacitor is selected in the coupling circuit.
- The input position is selected in the coupling circuit.
- All-vacuum tube design, all hand-made.
Specification
Power in Watt | 2×12W (RMS,8Ω) |
Power stage operating class | A/B |
Frequency response | 20Hz~20kHz -0.5dB |
Total harmonic distortion (THD%) | 1% (1 kHz) |
Signal to Noise Ratio | 86dB |
Colour | Black |
Rear entrances | 3 x Line-In (RCA) |
Exits Back | speaker terminals (4Ω, 8Ω) |
In addition | Tubes: 1 x 12AX7 / 2 x 12AU7 / 4 x EL84. |
Energy consumption | 120W max |
Dimensions | (W x D x H): 330mm × 180mm × 272mm |
Weight | 9kg |
- Number of posts : 5093
» Cayin MT-12N EL84 (Black) Integrated Amplifier (New Version)
» EL84 Tube Integrated Amplifier (Used) - SOLD
» Yarland Integrated EL84 Tube amplifier -sold
» Nimis LE EL84 Tube Integrated Amplifier SOLD
