Procella Audio 15 Inches Subwoofer from Sweden
Procella Audio Made in Sweden High-End 15 Inches Subwoofer for Both Music & AV Use-Complete Inside Box Brand New Condition.
Getting a new replacement amp directly from Sweden this month worth a few thousand ringgit. So basically this would be a brand new Subwoofer soon.
All the records and paperworks for this replacement will be given together.
Expanding the Procella subwoofer lineup in a slim, compact profile, the P15A is available in both black and white finishes. The active subwoofer drives its single 15 inch woofer with an onboard 350 Watt power amplifier. That 15 inch pro audio woofer driver features a 3 inch voice coil and cast aluminum chassis.
The built in Procella-designed amplifier delivers 350 Watts of class-D power, enabling the subwoofer to deliver 119 dB of output at 50 Hz. For room-shaking low frequencies, the P15A extends down to a -3dB point of 24 Hz.
Both XLR and RCA inputs are provided, and switchable room settings optimize the subwoofer’s response to room boundary conditions. The amplifier’s unique standby operation mode ensures that the subwoofer is activated from sleep mode before the program material begins. Thanks to its compact size and slim profile, the P15A is a highly versatile solution.
Its performance is outstanding whether in small to medium size rooms or in larger theaters where multiple subwoofers must be accommodated to balance low frequencies throughout the space.
Stockholm, Sweden and Venice, California – December 12, 2016 – Procella Audio, manufacturer of high-performance high-definition speaker systems for home and professional cinema and music applications, announced today the expansion of the Procella subwoofer lineup with the introduction of a new single 15 inch subwoofer, the P15A.
This high-performance high-output subwoofer features a shallow depth sealed-box cabinet and an integral 350 watt power amplifier. The P15A provides integrators and end users with a highly useful option, whether for small rooms or for larger theaters where multiple subwoofers are used to balance low frequencies throughout the space.
In a 55 liter sealed box enclosure, the P15A is built around a 15 inch long-throw professional audio subwoofer driver with a 3 inch voice coil and a cast aluminum chassis. Using a Procella-designed class-D 350 Watt power amplifier, the subwoofer produces a maximum output of 119 dB at 50 Hz, with extension to a – 3 dB point of 24 Hz.
“Historically, Procella has opted for dual-driver subwoofers to achieve maximum efficiency, dynamic range, and output,” stated Anders Uggelberg, Procella founding partner and designer of the P15A. “However, in smaller rooms, a single large-driver subwoofer can perform extremely well, and this is one reason we created the P15A.
Perhaps even more importantly, today’s most advanced theater systems use multiple subwoofers to achieve smoother bass response, In these rooms, subwoofer size an important consideration, especially when they may be placed in corners or at the midpoint of room walls.”
Complete set brand new condition inside box.
Selling for RM8900 now (negotiable for serious buyers) worth RM16k++ when brand new.
Condition: 9/10 (full complete set like new)
Please Whatsapp me at 012-5885270 for more details or photos.
Please check my other post for Procella Audio high-end matching speakers as well.
Well maintained in smoke-free and pets free environment.
Can arrange personal delivery within Penang, Kedah, KL & Perak areas or can arrange a courier to other places as these units are with original packing/boxes.
Thank you and please stay safe too.
-3 dB 24 Hz |
119dB @50 Hz |
Long-throw 15” driver with 3 inch voice coil and cast aluminum chassis in 55 litre sealed box |
Switchable Normal / Reversed |
User selectable: In corner / against wall |
350W, Digital Class D |
Balanced XLR, Single RCA input, Single RCA output |
100 – 250V, 40 – 80 Hz |
Programmable |
Full Power 440W, Standby <0.5W |
CCC certified, CE certified, FCC certified |
Heavily braced MDF |
Black semi-matte painted finish, White semi-matte painted finish |
HxWxD 19.875” x 27.5” x 9.65” / 505 x 700 x 245 mm / 58.4 Lbs / 26.5 Kg |
HxWxD 23.5” x 31.5” x 15.35” / 595 x 800 x 390 mm / 67 Lbs / 30.5 Kg |
Installation Guide, Power cord, Rubber mounting feet, XLR-RCA adaptor |
Sweden 100% QC testing |
Last edited by anandfm on Mon Mar 20, 2023 8:19 am; edited 4 times in total (Reason for editing : Update photos and info status.)
anandfm- Frequent Contributor
- Number of posts : 975
» Procella Audio Centre & Main Speakers Made in Sweden
» Procella P8 Centre Speaker New MK2 Version (Made in Sweden)-Brand New Inside Box
» Procella Audio P5v (Used Unit)
» PROCELLA AUDIO - P8 THX (Demo unit)
» DLS 10" Sub woofer-Sweden (Used)
