L.K.S. Audio MH-DA004 DAC (SOLD)
Two-chip ES9038pro decoding method.
Two high-quality toroidal transformers, a total of 13 groups of linear power supply.
Built-in specially designed Italian Amanero USB module, original license license. USB module added to isolate the chip, you can isolate the computer to the audio system interference signal.
Supports USB, I2S / DSD single-ended signal (RJ45), I2S / DSD balanced signal (HDMI), oaxial, BNC, AES / EBU balance, Optical total seven-way source input, all ports support DSD input.
Analog audio output port includes standard RCA single-ended output and XLR balanced output pair.
Display with VFD display, the display exceptionally outstanding.
Use physical key operation.
Support 0dB ~ -127dB digital volume adjustment, 0.5dB level. But also has a remote key to skip the volume adjustment function.
Support a variety of digital filter mode settings (see user manual). Can be arbitrarily selected, different filter mode, the digital filter attenuation characteristics are different.
Supports decoding of internal digital phase-locked loop bandwidth settings (see user's manual for details).
Support Deemphasis to increase or turn off.
The display has 4 levels of brightness adjustable. Adjusted by remote control.
Remote start, standby function.
Most of the settings with memory function, turn off the opportunity to automatically save the settings, restart the settings.
Dynamic range> 135dB
Distortion <0.0002%
Stereo resolution> 120dB
RCA unbalanced port output amplitude 2Vrms, XLR balanced port output amplitude 5Vrms.
Machine size 430 * 320 * 90mm
Machine weight 7.0kg
Conditions: 9/10 (USED)
- Number of posts : 5093
» Audio Research DAC8(sold)/ Audio Note CDT2 MK2(sold)- used
» Cambridge Audio CXN (V2) Series 1 Network Audio Streamer Player (Used) SOLD
» Cambridge Audio DVD89 SACD DVD Audio CD player (sold)
» Herbie Audio and Boston Audio Turntable Mat (SOLD)
» [SOLD] Burson Audio AB160 audio buffer
