NAD C350 60WPC 8ohm With Original Remote(sold)
Beautiful sounding Warm Amplifier
Careful Owner, Well Taken Care off
Unit comes with Original Fully Functional Remote Control
Unit is Fully Functional
Price: RMSold
Reviews :
http://www.tnt-audio.com/ampli/nad-c350_e.html
The NAD C350 has 7 line inputs (including 2 tape in/outputs with dubbing facility) and the pre-amplifier section can be separated from the power amplifier for easy upgrades or adding ancillary equipment. Thus the C350 can be expanded to meet future system needs. The C350 sports 2 pre-amp outputs: Many systems benefit from the use of multiple power amplifiers for "Bi-Amping" (using separate power amplifiers to drive the bass and treble section of a loudspeaker). With the second Preout 2 facility an extra power amplifier, such as NAD's forthcoming C270 which has identical amplification factor (gain) as the C350's power amp section- is easily connected.
Power output: 60 watts per channel into 8Ω (stereo)
Total harmonic distortion: 0.03%
Damping factor: 150
Input sensitivity: 325mV (line)
Signal to noise ratio: 96dB (line)
Dimensions: 435 x 100 x 290mm
Weight: 7kg
Price: RMSold
Reviews :
Damping factor: 150
Weight: 7kg
rkky- New Member
- Number of posts : 11
Registration date : 2011-07-15
» CD 960 Original Remote [ sold]
» Densen B-410 CD Player C/W Original Remote Control (Used) SOLD
» Rotel RCD-965BX CD Player with original remote (Used) SOLD
» Marantz CD63KI MKII with original remote control SOLD
» (SOLD!) Original DENON DCM-420 20bit 5 Disc Changer with Ori remote 90s model
