Axiom Audio M22 V3 Bookshelf Speakers, Canada
Axiom Audio M22 V3 Bookshelf Speakers for the Audiophile..
Are you ready to be blown away by a speaker with sound so detailed you’ll listen to every album you own all over again? Critics and customers alike rave about the detailed and highly realistic sound of the M22, Axiom’s best high-performance bookshelf speaker.
Noticeably taller than typical bookshelf
Trapezoidal design cabinet breaks up standing waves within the box to prevent sound colorization
Axiom’s Vortex-port to reduce port noise
Single bolt wall-mounting system – These are perfect for mounting on stands, walls or shelves.
The M22s deliver a soundstage of unprecedented depth and width, transporting you into the performance.
2-way, ported enclosure
1″ titanium dome tweeter (for V3 version)
2x 5.25″ aluminum cone mid/bass
The asymmetrical anti-standing-wave tapered shape of the cabinet is highly resistant to resonances that can color other speakers’ sound.
Freq Response: 60Hz – 22kHz
Impedance : 8 Ohms
Sensitivity : 89 dB (Anechoic) 93 dB (In-room)
Recommended Amp Power: 10-200 Watts
Dimension: H503 x W185 x D203 mm
Weight : 7.257kg
Boston Cherry Vinyl finish
The M22s are very efficient – you can use them with any receiver or amplifier, including a tube amp.
New tweeter exhibits increased dispersion, better linearlity off-axis which increases soundstaging.
Dual 5.25-inch woofer has excellent high power handling (up to 200 watts) and less compression at loud playback level than a single large woofer would.
Big advantage of smaller dual woofer remain smoother and more linear into the upper midrange.
Magnetic grille mesh
Solidly constructed cabinet.
“The M22s serve up a highly detailed, neutral, and well-balanced sound when paired with a good subwoofer.
After listening to the M22s for two months and playing countless tracks through them I have almost nothing negative to say about their sound.” – hometheaterhifi.com
” . . .the M22s simply dazzled us, especially considering their price point. They managed to create a wide-open soundstage, while at the same time portraying a precise stereo image. So precise that at times, these loudspeakers almost seemed to disappear into the room. ”
— Gene Della Sala, Audioholics.com
“Combine this speaker with a powered subwoofer in either a two-channel music system or a multichannel home-theater system and you have one heck of a full-range system for a previously unheard-of price.”
— John Potis, Goodsound.com
Its output and exceedingly natural sound outperform any speaker in its class:
“. . . this experience has forced us to re-evaluate what a pair of $1,000 speakers should sound like, because these certainly sound as good as any $1,000/pair speakers we have ever listened to.”
— Gene DellaSala, Audioholics.com
https://www.axiomaudio.com/m22-bookshelf-speakers
Made in Canada.
Great condition, 100% perfect working.
Comes with grille mesh (No Box)
RM1,390
Welcome for audition.
*Credit cards accepted.
Subang Jaya ss14
Contact 012 6116917
www.facebook.com/Actsessory/
» New Axiom QS8 Surround Speaker NEW(RM1800) ( Imported from Canada)
» psb Canada Bookshelf Speakers PSB-300
» Axiom Audio M22Ti speakers (Used)
» Special modded Mirage M-490 Hi-Fi audio bookshelf speaker 8" woofer 1" mordaunt short HE tweeter made in canada
» PSB 300 Bookshelf Speaker Canada.
