REL 212 SE SUBWOOFER (USED)
TYPE
(2) Front-firing active drivers, (1) rear passive, (1) down-firing passive
ACTIVE DRIVER SIZE & MATERIAL
(2) 12 in., 300mm long-throw, Continuous CastAlloy:tm: cone structure, cast chassis
PASSIVE RADIATOR SIZE & MATERIAL
(2) 12 in., 300mm Continuous CastAlloy:tm: cone structure, cast chassis
LOW FREQUENCY EXTENSION
-6dB at 19 Hz
INPUT CONNECTORS
High Level Neutrik Speakon, Low Level stero RCA, LFE RCA, SMA for wireless antenna
OUTPUT CONNECTORS
N/A
POWER OUTPUT
1,000 watts (RMS)
AMPLIFIER TYPE
NextGen3 Class D
WIRELESS CAPABILITY
Longbow (Optional), Zero Compression, Individual discrete D/A and A/D Encoders
Yes
D.C. FAULT
Yes
OUTPUT SHORT
Yes
MAINS INPUT VOLTAGE
220-240 volts, 1120-120 volts for certain markets
FUSES
7 Amp semi delay 220 volts operation, 15 Amp semi delay 120 volts operation
17.5 x 32 x 20 in. (444.5 x 815.5 x 507 mm)
NET WEIGHT
122 lbs. (55.3 kg)
CONDITION : 8.5/10
PRICE : RM12800 Per Unit
*IEC INLET UPGRADE WITH FURUTECH FI-33 NCF
FOR MORE INFO PLEASE CALL OR WHATAPPS :
018-9742567 YANG
016-5398723 YUAN
-6dB at 19 Hz
INPUT CONNECTORS
OUTPUT CONNECTORS
N/A
POWER OUTPUT
1,000 watts (RMS)
AMPLIFIER TYPE
NextGen3 Class D
WIRELESS CAPABILITY
[size=34]Protection System[/size]
FULLY ELECTRONIC SET SAFEYes
D.C. FAULT
Yes
OUTPUT SHORT
Yes
MAINS INPUT VOLTAGE
FUSES
[size=34]Dimensions[/size]
W X H X D17.5 x 32 x 20 in. (444.5 x 815.5 x 507 mm)
NET WEIGHT
122 lbs. (55.3 kg)
CONDITION : 8.5/10
018-9742567 YANG
016-5398723 YUAN
YUAN- Regular
- Number of posts : 68
» M&K subwoofer V90
» Auralex Subdude subwoofer platform and QED Reference subwoofer cable (sold)
» Rythmik F12 Direct Servo subwoofer 12″ sealed audiophile subwoofer
» Subwoofer -NHT10 Active subwoofer(sold)
» Rogers Subwoofer ASB-100 (Subwoofer)
