Cayin A-88T MK2 KT88 Tube Amplifier (Used)
Features:
- Four pieces of KT88 are used for Class AB push-pull amplification while input stage has taken 6SL7 and 6SN7 for voltage regulation.
- Designed with remote control and Triode and Ultralinear selection.
- User bias control is accessible with true ampere meter on the chassis.Two 6SL7s and two 6SN7s are used in the preamplifier.
- Can be used as a Power amplifier.
- High-quality Japanese ALPS motorized potentiometer.
- Thickly silver-plated signal cable has been used.
- Hand-made construction with the finest point-to-point wiring.
- Two EI output transformers with wide bandwidth and one specially-designed toroid power transformer are applied for A-88T MK2.
- A-88T MK2 can memorise the last operation state once switched off.
- Improved amplification circuit with Takman audio-grade resistors in key locations and Realcap PPMF-S series of high grade coupling capacitors being used to improve the sound.
- Soft start function (about 30 seconds) and other protection circuit has been used for better protection of power transformer and output transformers.
Specification:
Power output | 2*25w (8 Ω,Triode) 2*45w(8 Ω,Ultralinear) |
Frequency response | 10Hz~40kHz(-1.5dB) |
THD:1%(1kHz) | 1%(1kHz) |
Input sensitivity | 300mV 1000mV(Pre-in) |
S/N ratio | 93dB |
Input impedance | 100kΩ |
Output impedance | 4Ω, 8Ω |
Dimension | 420mm*382mm*195mm |
Weight | 28 |
Power consumption | <280w |
Tube | KT88*4 , 6SN7*2, 6SL7*2 |
Conditions: 8/10 (USED)
Price: RM4,000 inclusive postage to West Malaysia
- Number of posts : 5092
» SOLD Cayin KT88 MK1 Intergrated Tube Amplifier
» Cayin MT45-mk2 KT88 Tube Integrated Amplifier UL/Triode
» Cayin MT-45 MK2 plus KT88 Hi-End Audiophile Tube Amp
