VAC Signature 200iQ Stereo Power Amplifier
VAC Signature 200iQ Stereo Power Amplifier Empty VAC Signature 200iQ Stereo Power Amplifier
Post by raymond88 Mon Jan 30, 2023 5:00 pm
Item: VAC Signature 200iQ Stereo Power Amplifier
Condition: Item is in LIKE-NEW condition. No dents or scratches. Comes with power cable.
Price: RM38,000 RM36,500 or swap/topup
VAC Signature 200 iQ Power Amplifier
This 100 watt per channel stereo, 200 watt monoblock powerhouse features the exclusive patented *VAC iQ Continuous Automatic Bias System, the only system able to hold each power tube’s true underlying idle current perfectly steady at all times.
The results? More detail, increased subjective power, greater stability, lower noise, less distortion, and no more runaway tubes.
It will even tell you when it’s time to replace weak tubes.
The iQ System. Superior sound. Only from VAC.
VAC Signature 200iQ Stereo Power Amplifier Vac111
VAC Signature 200iQ Stereo Power Amplifier Vac211
VAC Signature 200iQ Stereo Power Amplifier Vac311
VAC Signature 200iQ Stereo Power Amplifier Vac710
VAC Signature 200iQ Stereo Power Amplifier Vac610
VAC Signature 200iQ Stereo Power Amplifier Vac810
VAC Signature 200iQ Stereo Power Amplifier Vac410
VAC Signature 200iQ Stereo Power Amplifier Vac510
Specs:
Type: Vacuum tube power amplifier with transformer coupled output
Features:
VAC iQ Continuous Automatic Bias System ™
Class A1 triode input & driver stages
Direct coupled input & driver stages
Low feedback design (6 dB)
12 volt trigger
Detachable power cord
IEC power receptacle
Switch Settings:
Fully balanced or single-ended input
Stereo or mono operation
Power Output:
100 watts/channel stereo continuous
200 watts mono continuous
Speaker Matching Taps: 1-2 ohms, 2-4 ohms, 4-8 ohms
Frequency Response: 4 Hz to 85 kHz, +0/-3 dB
Full Power Bandwidth: 13 Hz to 70 kHz, +0/-3 dB
Residual Noise: Typically > 95 dB below rated output
Input Impedance:
200k Ohms, Stereo, Balanced
100k Ohms, Stereo, Single Ended
100k Ohms, mono, Balanced
50k Ohms, mono, Single Ended
Gain:
30 dB, Stereo, Balanced
33 dB, Stereo, Single Ended
31 dB, Mono, Balanced
34 dB, Mono, Single Ended
Output Polarity:
Non-inverting.
Balanced input is Pin 2 positive.
Tube Complement:
4 x type 6SN7
4 x type KT88
Compatible with KT120
Electrically compatible with KT150 (may be too tall to fit under the cage)
Operating Voltages: Available factory set for 100, 120, 220, or 230/240 volt operation
Connectors:
Cardas rhodium RCA jacks
Neutrik XLR jacks
Cardas rhodium binding posts
Dimensions:
18″ W x 17.25″ D x 8.75″ H
457 mm x 438 mm x 222 mm
Excluding knobs & connectors
Weight: 100 lbs.
Origin: Designed & manufactured exclusively in the United States of America by VAC
http://www.vac-amps.com/productPages/Signature200.html
https://www.soundstageultra.com/index.php/equipment-menu/762-vac-signature-200iq-stereo-amplifier#most-read-equipment-reviews
https://scottwalkeraudio.com/brands/vac/vacpoweramps/signature-200iq/#:~:text=VAC%20Signature%20200%20iQ%20Power%20Amplifier,perfectly%20steady%20at%20all%20times
https://www.hifinews.com/content/vac-master-preamplifiersignature-200iq-pre-power-amplifier
Number of posts : 8957
VAC Signature 200iQ Stereo Power Amplifier Empty Re: VAC Signature 200iQ Stereo Power Amplifier
Post by raymond88 Tue Feb 07, 2023 9:55 am
Post by raymond88 Tue Feb 14, 2023 12:43 pm
Post by raymond88 Wed Feb 22, 2023 11:05 am
