ATC SCM 20-2 Active Monitor (used)
Specifications :
Drivers : HF 25mm, Mid/LF 75/150mm
Amplifier Output : HF 50w RMS, Mid/LF 200w RMS
Amplitude Linearity (±2dB) : 70Hz-17kHz
Cut-off Frequencies (-6dB, free-standing) :
45Hz, 22kHz
Horizontal Dispersion : ±80°, Coherent
Vertical Dispersion : ±10°, Coherent
Max. Continuous SPL (1 meter) : 108dB
Crossover Frequency : 2.8kHz
via active crossover with time (phase) alignment
Input Sensitivity : 1VInput Connector : Balanced male XLR
Input Impedance : > 10kΩ
Overload Protection : Active momentary
gain reduction (Both amplifiers)
Power Requirements
Voltage : 100, 115, 230 (factory set)
Frequency : 50/60Hz
Power : Nominal 50 Watts, driven 250 Watts
Dimensions (HxWxD) : 470 x 285 x 395mm
Weight : 27kg / 60lbs (each)
Condition:8/10
Price:RM12800(INCLUDE A PAIR OF STAND)
018-9742567 YANG
016-5368723 YUAN
45Hz, 22kHz
Power Requirements
Frequency : 50/60Hz
Condition:8/10
018-9742567 YANG
016-5368723 YUAN
YUAN- Regular
- Number of posts : 72
» Monitor Audio ASW Active subwoofer
» Monitor audio fastbasss fb 110 active subwoofer (Used)SOLD
» Monitor Audio Bronze W10 Active subwoofer (Sold)
» Tannoy System 800 Active Monitor Loudspeakers (Used) SOLD
» [Price reduced] Magnat Multi Monitor 220 Active Speakers
