Mission 761 bookshelf speaker, England
Mission 761 bookshelf speaker, England.
Compact 2-way loudspeaker system of airtight / sealed type.
Made in England.
The MISSION 761 was developed as an advanced model of the classic Mission 700LE, which became a best-seller as a synonym of Mission speaker over the past 10 years or more.
761 has a design with tweeter on bottom and woofer on top.
As a result, the distance from sound center to ear of each unit is made equal, and sound image localization and sound field are improved.
175mm (7″) ultra-rigid Plastiflex cone woofer with motor system of specially shaped pole piece and ultra-fine voice coil gap for controlled, extended bass performance.
19mm soft polymer dome tweeter of ferrofluid cooling for improved linearity, greater power handling and significant reductions in distortion and sibilance.
18mm thick plate material is used for the enclosure.
The matchless dispersion, high sensitivity and broad dynamic range make the Mission 761 an ideal compact monitor for both digital and analogue source material.
Freq response: 58Hz to 20kHz
Impedance of 6 Ohms
Sensitivity: 89dB
Recommended Amplifier Power: 20 – 75 watts
Max SPL per pair: 104dB
Dimension: W210 x H380 x D220 mm
Weight : 5.1kg
Comes with grille mesh (No Box)
Good used condition.
RM 650
Welcome for audition.
*Credit cards accepted.
Subang Jaya ss14
Contact 0126 116917
www.facebook.com/Actsessory/
» Mission 73 England Made Bookshelf Speaker ( used)
» Mission 760i Special Edition England made bookshelf speaker
» Marantz SR4300 with mission 734 speaker from England
