XY Screen 4K Cinema 120" Fixed Frame Projector Screen (Used)
XY Screen 4K Cinema 120" Fixed Frame Projector Screen (Used) Empty XY Screen 4K Cinema 120" Fixed Frame Projector Screen (Used)
Post by choyaudiovisual Thu Mar 02, 2023 8:18 am
XY Screen 4K Cinema 120" Fixed Frame Projector Screen (Used) O0o-610
XY Screen 4K Cinema 120" Fixed Frame Projector Screen (Used) Image_10
Fixed Frame Projection Screen 60B Series
 ◆◆ Product  Description
XY screens Fixed Frame Screens are perfect for cinemas or any places where you need to fix the screen. It is enclosed in an attractive velvet wrapped lightweight aluminum alloy frame. HK60B Series Fixed Frame Screen provides excellent picture quality – Suitable for 4K&3D television/movies.
Installation is easy – With its easy and adjustable fabric spring system, our Fixed Frame Screen is perfectly and permanently tensioned, ensuring that the screen is as flat and level as the mirror. Special designed slim bracket for an easy click on installation, also available as an in-wall display. Therefore, the users are able to set up in seconds.
◆◆ Product  Specification
Frame Material:Aluminum Alloy
Housing Color:Black
Aspect Ratio:16:9
Frame Width:60mm
HD:Yes
3D:Yes
4K:Different fabrics are optional
Conditions: 8/10 (USED)
Price: RM800 inclusive postage to West Malaysia
Number of posts : 5239
geforce1999 likes this post
