Monitor Audio Silver RX2 Bookshelf Speaker
The RX2 is larger and designed as audiophile compact 2-way speaker.
Having efficiency and bandwidth of a much larger speaker.
It offers extended high frequencies to resolve hidden detail, coupled with immense dynamic headroom and bass depth.
* C-CAM
* 8” bass driver with C-CAM
* Cast polymer bass chassis design for rigidity and low reflection properties
* HiVe
* Single bolt through driver system, for increased overall bracing and rigidity.
* Rigid 19mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
* Invisible magnetic grille provides clean visual styling when used with the grille off
* Premium quality Rosenut wood veneers finish.
2-Way
Freq Response: 40Hz – 35kHz
Sensitivity : 90dB
Nominal Impedance: 6 Ohms
Power Handling: 100 Watt
Rec. Amp Requirement: 25-100W
HiVe
1 x 8″ RST
1 x 1″ (25mm) C-CAM
Dimension: H375 x W230 x D300 mm
weight : 9.5kg
“The sonic scale was really big.
Its larger mid/woofer showed its mettle over the smaller ones of the competition.
Monitor Audio’s Silver Rx2 very astutely differentiated between recordings.
The RX2 better differentiated between disc dynamics and recording techniques.
When switching to the XRCD disc Quiet Kenny by Kenny Dorham, it was obvious how this technology produces a much warmer sound.
The London disc issued on HQCD wasn’t worse, mind you. The XRCD was simple warmer and silkier.” http://www.6moons.com
In great condition.
Comes with magnetic grille mesh, jumpers and box.
RM2,050
Welcome for audition
*Credit cards accepted
Subang Jaya ss14, contact 012 6116917
www.facebook.com/Actsessory/
» Monitor Audio Silver RS1 Bookshelf Speakers (Sold)
» Monitor Audio Monitor Gold 7 Bookshelf Speaker (Sold)
» Monitor Audio Monitor 7 Gold Bookshelf Speaker
» Monitor Audio RS silver series speaker package (RS1 Bookshelf, RS Centre , RSFX Dipole surround) SOLD
» Monitor Audio Silver RX2 Bookshelf (Sold)
