Karan KAL Reference MK3 Flagship Preamp
Mint and Pristine condition and Brand New in BOX Karan KAL Ref MK3 Pre amplifier for sale. Black Colour and comes with All accessories, Manual and remote with Original Box. Local Singapore dealer set. Please visit Singapore for purchasing. Full Demo and Testing, inspections can be done until fully satisfied. Selling at SGD 15,200.00 and negotiable for serious buyers.
KA–L Reference Mk3 is ultimate statement, with all of our knowledge and experience built into it. The best passive components that can be found on the market are being used in order to gain the best results possible, which contributes the quality of sound, but also has positive influence on reliability of Karan Acoustics amplifiers and preamplifiers. There could be no other way – as the central unit in an audio chain, it simply demands the best. Completely balanced, dual mono circuit topology, with 24k gold plated circuit boards, all stages are DC coupled and operate in pure class A. In order to achieve the best results possible it was necessary to divide power supply into a separate casing, which brought its influence on electronics to a minimum. In order to avoid inherent nonlinearities of potentiometers, this preamp uses a four-gang attenuator, with 64 positions, implemented by using highest quality vacuum relays and fixed value 0.1% tolerance metal film resistors due to high sensitivity to interference of preamplifiers. The huge power supply has been relegated to a separate case of its own, and has been made ultra stable using four stabilization levels per channel. For vinyl lovers we can offer phono board which can be build into this preamplifier.Using several newly developed proprietary solutions, this preamplifier yields absolutely no sonic colorations, huge soundstage, deep and tight bass and polite mid and highs.
Technical data:
Technical data:
- Completely balanced, dual mono circuit topology with no overall feedback
- All stages are DC coupled and operate in true pure class A;
- Separate power supply;
- In order to avoid inherent nonlinearities of potentiometers, this preamp uses a four-gang attenuator, with 64 positions, implemented by using highest quality vacuum relays and fixed value 0.1% tolerance metal film resistors;
- Due to high sensitivity to interference of preamplifiers, the power supply has been relegated to a separate case of its own, and has been made ultra stable using four stabilization levels per channel;
- The preamp is remote controllable
- An ultra high precision optional MM/MC phono RIAA board is available, with a response precision of +/- 0.15 dB;
- Overall frequency response of line inputs is DC-300kHz, +0, -3dB;
- Intermodulation distortion is below 0.006%;
- Input sensitivities: RCA-line= 750mV/30k; XLR-line= 1,5V/30k;
- Line level input S/N ratio is better than -112 dB;
- Output level: 6V/0.6 Ohms;
jmjantony- New Member
- Number of posts : 3
Registration date : 2023-08-15
» WTS: Hi end Karan KAL Ref Preamp MK2(Used)
» (Sold) Karan KA L Reference Preamp MK 2
» Emotiva flagship XSP 1 preamp with MM/MC phono etc, etc
» Karan KAS600 + KAL Ref MK3 pre amp (Sold)
» Karan Pre-amp KAL REF Mk3
