Parasound A23 Power amplifier
Used in good condition 9/10
Continuous power output:
125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven
225 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
Single channel 400 watts RMS, 20 Hz - 20 kHz, 8 Ω
Damping factor : > 800 at 20 Hz
Selling for RM3380
Contact Peter 012-3820333
Circuitry designed by legendary John Curl
High bias Class A/AB operation
Balanced inputs with discrete circuits and XLR connectors
Direct Coupled - no capacitors or inductors in signal path
Complementary MOSFET driver stage and JFET input stage
12 beta-matched 15 amp, 60 MHz bipolar output transistors
1 kVA encapsulated toroid power transformer with independent secondary windings for each channel.
40,000 μF power supply filter capacitance
DC Servo and relay protection circuits
AC present, channel status, high temperature displays
Heavy-duty 24k gold-plated 5-way speaker binding posts
Gold-plated RCA input jacks; loop output jacks
Rear mounted gain controls, ground lift switch
Selling for RM3380
- Number of posts : 2095
» Parasound A21 Power Amplifier(sold)
» Parasound A23 Power Amplifier (used)
» Parasound 6-channel power amplifier
» Parasound A51 Power Amplifier [SOLD]
