Rythmik FVX15 Direct Servo Audiophile Subwoofer, 15″ ported sub
“Bang for buck” home theater solution of dynamic and accurate bass..
Tight bass of the sealed subwoofer, yet with greater low frequency output.
Can select either one-port (extends to 12Hz) or two-port operation (foam plug is included)
Direct Servo tech which precisely controls the cone for tight, dynamic and accurate bass, higher efficiency, deeper bass extension etc.
*400W RMS amplifier
*New Hypex Ucd model based HX405 amplifier as one of the best sounding Class D module
*Toroidal transformer power supply with 2x large US-made (CDE) power filter capacitors to ensure power supply stability.
*15″ anodized aluminum DS1502 driver of double stacked 25mm magnets to improve excursion limit, custom sensing coil
*Dual large 4″ port with 2 tuning frequencies.
Freq Response: 12-200Hz
Black matte finish
Bass extension controls
Crossover options
Rumble Filter
Phase adjustment
Bass damping factor setting
PEQ
Dimension: W18″ x H24″ x D24″
Weight : 54.0kg
Comes with port plug foam, power cord and grille mesh (No Box)
Used, good condition, perfect working.
2 units available, RM5,250 each.
Welcome for audition
Subang Jaya ss 14
**Credit Card accepted
Contact 01261 16917
www.facebook.com/Actsessory/
» FVX15 Direct Servo Subwoofer 15″ ported audiophile sub
» Rythmik F12 Direct Servo Subwoofer
» Rythmik F12G PEQ 12" Sealed Audiophile Direct Servo Subwoofer
» Rythmik F12 Direct Servo subwoofer 12″ sealed audiophile subwoofer
