GoldenEar Invisa HTR7000, In-ceiling Home Theater Reference loudspeaker
Top-of-the-line GoldenEar Invisa HTR-7000 (Home Theatre Reference) in-ceilig speakers combining GoldenEar’s FocusField technology with unique Non-Periodic Waveform (NPW) Diffration Control, and Wave-Launch construction.
Angled-driver design lets you install your HT speakers in ceiling for surround sound without clutter, projecting the sound towards listener’s position.
GoldenEar’s highly acclaimed HVFR (High Velocity Folded Ribbon) tweeter for its wide dispersion, smooth response all the way to 35kHz, detail and transparency.
With 3-position high-frequency EQ switch to cut or boost high-freq output to best match your room acoustics.
Beefy 7″ woofer provides detailed midrange and punchy bass, with extra-strong magnet keeping its movement linear and clean.
GoldenEar’s MVPP (Multi-Vaned Phase Plug) controls energy of the driver and minimizes cone diffraction.
Freq Response: 25Hz – 35kHz
Recommended Amp Power: 10W to 250W
Sensitivity : 90dB
Impedance : 8 Ohms
Ultra-thin bezel and paintable magnetic grille for seamless integration
*High performing, high value speaker
*Easy to install
*Modern ribbon tweeter for excellent transients and clarity
*High efficiency
*Deep bass
Dimension: 269mm (10″) diameter, 126mm (5″) depth
Cutout: 229mm (9″) diameter
Weight: 2.0kg
Comes with grille mesh (No Box)
Great condition, 100% perfect working
RM3,900
Welcome for audition.
Subang Jaya ss 14
**Credit Card accepted
Contact 01261 16917
www.facebook.com/Actsessory/
» GoldenEar Invisa 525 (SOLD)
» WTS: Epson Home Cinema TW8300w WirelessHD 3LCD Home Theater Projector
» Home Theater PC
» 5.1 Home Theater Set
» FS: 5.1 NHT Home theater sold......
» Home Theater PC
