Counterpoint SA-20 hybrid tube mofset power amp
Counterpoint SA-20 hybrid tube mofset power amp Empty Counterpoint SA-20 hybrid tube mofset power amp
Post by jbashok Mon Jun 24, 2024 9:51 pm
Counterpoint SA-20 hybrid tube mofset power amp Img_1623
Counterpoint SA-20 hybrid tube mofset power amp Img_1625
Counterpoint SA-20 hybrid tube mofset power amp Img_1624
Counterpoint SA-20 hybrid tube mofset power amp Img_1617For sale
Rm5820
www.wasap.my/60143413655
Counterpoint SA-20
Hybrid tube dual channel power amp
Voltage 240v
Made in USA 🇺🇸
Cosmetic near mint
Perfect working condition
Power output: 220 watts per channel into 8Ω (stereo), 600 watts into 8Ω (mono)
Frequency response: 1.2Hz to 200kHz
Total harmonic distortion: 0.5%
Damping factor: 6
Gain: 29 dB
Signal to noise ratio: 84dB
Valve complement: 5 x 6DJ8, 1 x 6CA4
Dimensions: 480 x 113 x 480mm
Weight: 69lbs
https://audio-database.com/COUNTERPOINT/amp/sa-20.html
https://www.ebay.com/itm/133636032027?itmmeta=01HZTVR42SJZ86BA8V0S6XK7WM&hash=item1f1d54061b:g:XjEAAOSwsKdf~QZw&itmprp=enc%3AAQAJAAAAwLB7l6m98vROJ5L3E20fhmfnH2spRu65KAiirxKJGFWkoUQhzJqqe3auYVxmwZeDv%2BL3OobxfJ1lBS393hunA0YMRF2C0%2FLqQfe8ykOyWAidCRP5CcCluTAaqsiSbgjAfsUAKvkD9G03%2Fe%2Bpy9dN8qsOA34KXw4LOTlrPD%2FRFmxcQd2Y5flRRI%2F%2BmExo0IojJsFfQ90VK51lC06YZHrKszvqUntiIcEXzwsZYyDbykcbUPuFkfPvM3R%2FLSr1JNIC2w%3D%3D%7Ctkp%3ABk9SR77B4Nv-Yw
jbashok
Number of posts : 2958
Counterpoint SA-20 hybrid tube mofset power amp Empty Re: Counterpoint SA-20 hybrid tube mofset power amp
Post by jbashok Sun Jul 28, 2024 2:27 pm
Up
jbashok
