SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Empty SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set
Post by actsessory Wed Jun 26, 2024 10:05 am
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Svs-ultra-7-1-01
SVS Flagship Ultra Tower Floorstand Reference Speaker
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set St2
Flagship SVS floorstanding speaker stands toe-to-toe with the finest loudspeakers in the world delivering reference sound for music and home theater.
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Stower2
Custom drivers, SoundMatch 3.5-way crossover, and optimized cabinet geometry, the Ultra Tower is engineered for breathtaking home audio experiences.
Freq Response: 28Hz – 32kHz
Impedance : 8 Ohms
Sensitivity: 88dB
Recommended Amp Power: 20-300 watts
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set St5
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set St4
Dual gold-plated 5-way binding posts
3.5″ wide-flared rear-firing port
1″ Aluminum Dome Tweeter
2x 6.5″ Midrange Drivers
2x 8″ Woofers
3.5-way crossover with premium-grade capacitors, air-core inductors and heavy-trace printed circuit boards
Separate sealed midrange enclosures
Non-parallel cabinet panels
FEA-optimsed bracing, 1″ thick midrange/tweeter baffles, 1.5″ think woofer baffles
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Stower1
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set St6
Dimension: H115.82 x W35.05 x D42.67 cm
Weight : 34.2kg
Used, in great working condition.
Comes with spike feet, grille mesh, jumper (No box)
__________
SVS Ultra Center, Reference 3-way Speaker
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Sc1
Reference 3-way SVS Ultra Center speaker with stunning dynamics, massive soundstage, pristine clarity for unerring realism and dialogue intelligibility.
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Scenter2
– Dual 6.5″ woofers
– 4″ vertically-aligned midrange
– 1″ dome tweeter
*Outstanding dispersion characteristics for accurate frequency response.
*Acoustically enhanced cabinet geometry to the high-end components and build quality, the Ultra Center is a star among home theater speakers.
**High performance:price ratio, you get more than what you pay..
SVS Ultra Center combines power and precision to outperform much larger and more expensive center channel speakers.
“The reason why I loved these is essentially the smoothness of the mid and treble frequencies. Very clear, but not harsh. I also liked the very fat sweet spot; you could sit basically anywhere and still have fantastic imaging.”
Center channel, is by far the most important speaker to have, all the dialogue is sent to center, in a properly mixed audio stream.
Having a good center channel, does wonders for overall clarity, greatly enhance dialog in movies.
Thus an ideal center speaker is critical for best listening results.
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Sc2
Comes with grille mesh, jumper (No Box)
Used, great working condition.
____________
SVS Ultra Bookshelf Speaker, Gloss Piano Finish
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Sb4
Reference bookshelf speakers with flawless tonal balance, stunning dynamics, unveiled highs and amazing low frequency extension.
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Sbookshelf2
6.5″ Glass-fibre cone Woofer
Freq Response 45Hz – 32kHz
Nominal Impedance 8 Ohms
Sensitivity 87-90dB
Recommended amp power 20-150 watts
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Sb2
Performance Driven Cabinet Design and Geometry
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Sbookshelf3
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Sbookshelf-1
SVS Reference Ultra Tower Floorstand, Center, Bookshelf Speakers 7.0 set Sb3
2 Pairs available.
Comes with speaker jumper, grille mesh (No Box)
All 7 speakers for RM15,580
*Credit cards accepted.
Welcome for audition at Subang Jaya ss14
Contact 012 6116917
www.facebook.com/Actsessory/
actsessory
Number of posts : 2522
http://www.actsessory.com
