Denon DP-3000NE Premium Direct-Drive Turntable
Denon DP-3000NE Premium Direct-Drive Turntable Empty Denon DP-3000NE Premium Direct-Drive Turntable
Post by stylelaser.com.my Sat Jul 13, 2024 7:52 pm
Denon DP-3000NE Premium Direct-Drive Turntable Brand NewNow Selling At RM13,399. Free Shipping Within West Malaysia.
Denon DP-3000NE Premium Direct-Drive Turntable L173
DP-3000NE
Premium direct drive Hi-Fi turntable
Overview
This is the flagship premium direct-drive turntable from Denon®. Solid construction and S-Shape tonearm deliver detailed, resonance-free music. And the dark ebony natural wood veneer makes it a beautiful addition to your space.
Key Features
  • Accurate playback
  • Direct-Drive motor
  • S-Shape tonearm
  • Vertical tracking
  • Adjustable insulator feet
  • Solid construction
  • Removable dust cover
A TURNTABLE MASTERWORK
With equal parts beauty and sound quality, the DP-3000NE aims to change how you feel about sound.
PREMIUM DIRECT-DRIVE HI-FI TURNTABLE
Premium direct-drive turntable with Denon® S-Shape tonearm, solid construction, and stunning design.
Denon DP-3000NE Premium Direct-Drive Turntable 01C326C8B0F541C99820D2C672C13B63
SOLID CONSTRUCTION
Solid construction and sturdy adjustable insulator feet provide the strength needed to reproduce detailed, resonancefree music.
Denon DP-3000NE Premium Direct-Drive Turntable B3C31CDE368E4AFFB8FDEB203E4324DC
BEAUTIFUL DESIGN
Dark ebony natural wood veneer and metal platter, tonearm, and controls look stunning in your space.
Denon DP-3000NE Premium Direct-Drive Turntable 51B9A97995BE4220A785D04FF6CA12D3
DENON ORIGINAL STATIC BALANCE S-SHAPE TONEARM
Features a carefully engineered S-Shape tonearm suppresses vibration and optimizes tracking angle at any point of the record.
FULL ADJUSTABILITY
Several adjustment options allow the use of a wide variety of MM or MC cartridges. And with 9 mm vertical height adjustment at the tonearm base the vertical tracking angle can be easily adjusted.
DIRECT-DRIVE MOTOR
Simple to use with rotation speed that does not fluctuate, no matter the selected speed or load, and reaches full speed almost instantly. No aging belt to be replaced in the future.
SPACE VECTOR PWM MOTOR CONTROL
SV-PWM is an algorithm to control the motor’s power supply to greatly reduce harmonics and ensures continuous reliable voltage for highly accurate speed.
SPEED SELECTOR
Easily play your entire vinyl collection with playback at 33 1/3 rpm, 45 rpm, and 78 rpm.
Direct-drive motor system
Follows a long Denon tradition of direct-drive motor system, with rotation speed that does not fluctuate no matter the selected speed or load. Simple to use, low maintenance, and reaches full speed almost instantly. Denon released its first direct-drive turntable, the DN-302F, for broadcast studios in 1970.
Denon original static balance S-Shape tonearm
Features a carefully engineered S-Shape curved tonearm with optimized tracking angle at any point of the record. This newly improved Denon® arm features cartridge weight adjustment, anti-skating adjustment (0-3 g) and a newly developed arm height adjustment (0-9 mm). It gives you full flexibility to customize your turntable to your preferred cartridges or custom mat.
Space vector PWM motor control
Space vector pulse width modulation (SV-PWM) is a new design for the motor spinning control. SV-PWM is simply an algorithm used to control the PWM (pulse width modulation) module, which basically powers the motor. SV-PWM greatly reduces harmonics in the motor which can cause overheating and torque fluctuations and offers a continuous reliable voltage and frequency output for long periods of listening at any rotation speed or load via continuous feedback of the rotation speed.
SMPS power supply
Switch mode power supply (SMPS) greatly benefits turntables by avoiding the use of a linear transformer, avoiding unnecessary vibrations. It allows integration of the power supply into the turntable, getting rid of any external power transformer or power bricks dangling behind the product. It also avoids voltage and frequency fluctuations from variation in the power grid.
The feet are key to protect the playback from any vibration picked up from the surface the turntable is placed on. But these feet are also adjustable to bring the platter perfectly in balance for the most accurate tracking of the needle in the groove.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Denon DP-3000NE Premium Direct-Drive Turntable Trade
Technical Information
  • Drive SystemDirect
  • Motor16-pole, 12-coil, brushless motor
  • Control methodPWM Vector
  • PlatterAluminum diecast (305mm)
  • Platter inertia382 kg/CM^2
  • Wow Flatterless than 0.06% JIS
  • Speed toleranceless than ± 0.3%
  • Rumble (S/N ratio)Over 70dB
  • Bearing TypeMiniature Steel ball bearing
  • Tone ArmStatic Balanced S-Shaped
  • Arm length244 mm
  • Overhang14 mm
  • Offset angle20.5 °
  • Tracking error angle2.5° (Max.)
  • Suitable cartridge weight4 to 16g without sub weight
    14 to 26g with sub weight
  • Stylus force adjustment0 - 2.5g /rotation
  • High adjustment range9mm
  • Anti-skating adjustment0-3g
  • Headshell materialAluminum
  • Sensitivity (Horizontal)30mg
  • Sensitivity (Vertical)30mg
  • OperationManual
  • Speed33 1/3 / 45 / 78 rpm
  • ControlStart / Stop
General
  • ColorsDark ebony
  • Dimensions500 x 394 x 185mm (W x D x H)
  • Weight18.5 kg
  • Power SupplyAC 100-240V, 50/60Hz
  • Power consumption<4W
  • Stdby Power consumptionLess than 0.3W
  • Carton maximum Dimensions615 x 515 x 335 mm (W x D x H)
  • Carton Weight24.0 kg
  • What's in the boxPlatter mat, Dust cover, Power cable, RCA cable and ground cable, Headshell, Overhang gauge, Screw set for cartridge mount (10, 13, 18mm), 2 x Cartridge spacers (1 mm), 2 x Plastic Washer, Screw driver, Counter weight, Sub-counter weight, Denon EP adapter/weight
Number of posts : 1411
