Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series"
Item: Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series"
##BRAND NEW IN BOX##
Retail Price: RM6999
Last Set Clearance Price: RM4100!!!
First Come First Serve
Price: RM4100 or swap/topup
Velodyne DB12
The Velodyne DB12 is part of the new Deep Blue (DB) series Sub Woofer platform development based on Velodyne Acoustics technologies with a modern styling, unmatched performance with a dynamic and accurate output. This Platform is a completely new industrial design, new driver technology and a new Amplifier design.
The new DB Sub Woofer line-up is the predecessor of the successful SPL I series, a very small form factor closed box design.
The completely new rigidly braced MDF closed box design with a front firing woofer for impacting performance without any noise from the cabinet. Due to this small form factor it is easy to integrate into you listening set-up. A high excursion driver with massive dual ferrite magnet and optimised internal motor technology using a 4 layer voice coil for maximum output with extremely low distortion, following the Velodyne Acoustics design principles. Superior bass quality, for a deeper, more accurate bass performance. Line-level and speaker-level inputs let you connect this Sub Woofer to just about any home audio system.
You can use the variable crossover and phase control to fine-tune the sub’s output, so the bass will blend in perfectly with the mids and highs coming from your main speakers, tailor the sub’s low-frequency response to the acoustics of your room.
Key Features
Closed Box Design: Completely new rigidly braced MDF closed box design with a front firing woofer
4 Layer Voice Coil: 4 layer voice coil for maximum output with extremely low distortion
High Excursion Driver: High excursion driver with massive dual ferrite magnet
High Flexibility: Line-level and speaker-level inputs for maximum flexibility
Velodyne DB12
Key Features
» Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series"
» Velodyne DB12 12" Sealed Box Powered Subwoofer
» USED Velodyne DD+ 12 Active Subwoofer
