Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC
Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC Empty Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC
Post by raymond88 Sat Aug 10, 2024 1:26 am
Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC Musica42
Item: Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC
Condition: Item is in excellent condition. Comes with an original remote control, manual, power cord and original box.
Price: RM2800 or swap/topup
Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC Musica37
Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC Musica40
Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC Musica39
Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC Musica41
Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC Musica38
Musical Fidelity M3S CD
1.479,00 €
CD Player and Digital Hub
The M3scd provides excellent CD playback and can act as a versatile digital hub, making it a valuable addition to your audio setup.
Performance and Versatility
In addition to playing CDs, the M3scd features three digital inputs: coaxial, optical, and asynchronous USB. These inputs make it particularly useful for enhancing the sound of set-top boxes and TVs. The M3scd's technical performance is excellent, with very low distortion, extremely low jitter, an excellent signal-to-noise ratio, an extremely flat frequency response, exemplary linearity, and excellent channel separation.
Build Quality and Convenience
The M3scd is built with high-quality materials and has a convenient size, making it an excellent addition to any audio system.
Features
CD player and digital hub
Excellent technical performance
Very good CD readability
Multiple digital inputs: coaxial, optical, and asynchronous USB
Very low jitter
High-quality build and convenient size
Technical information
Performance
Jitter: <135 picoseconds peak to peak
Frequency Response: 10Hz to 20 kHz -0.2dB max.
Signal to Noise Ratio: >117dB
THD(+ noise): <0.003% 10Hz to 20 kHz
Linearity: <0.1dB down to -96dB
Channel Separation: 105dB 20 Hz to 20 kHz
Hardware
DAC:24 bit Delta-Sigma (bit stream) dual differential 8x over-sampling
Outputs
1x line level RCA
1x RCA coaxial connector (Digital SPDIF)
1x Toslink optical connector (Digital SPDIF)
1x Trigger output - 3.5mm (1/8”) mono jack +12V DC
Inputs
1x RCA coaxial connector SPDIF 32-192kHz
(16-24 bit stereo PCM)
1x TOSLINK optical connector 32-96kHz
1x USB type ‘B’ connector -
Asynchronous data stream at up to 24-bit/96kHz
Trigger in
General
Dimensions - WxHxD (mm): 440 x 100 x 380
Weight (unpacked / packed): 6.05 kg / 9.9 kg
Press Reviews
"With the M3si a classy midprice combo with genuine appeal."
- HI-FI CHOICE
"Sensitive, precise, very relaxed. Price/performance: outstanding"
- ROLAND KRAFT - STEREOPLAY
"Good sound - top equipment."
- TOM FRANTZEN - STEREO
"Both thumbs up for the M3sCD!"
- ALEX RÖSER, STEFAN GOEDECKE - AUDIO TEST
https://www.hifihut.ie/products/musical-fidelity-m3s-cd-player?srsltid=AfmBOoq4KncLl1Zk_QULO3gwsBQELdTzZFwMCnSBFiso7IgdB8vflcoY
https://upscaleaudio.com/products/musical-fidelity-m3scd-cd-player?srsltid=AfmBOooOyurLMQr5dvmsWD0A1kGGE5cDazVmLlTNJKUa0-xk77sGKC8U
Number of posts : 10430
Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC Empty Re: Musical Fidelity M3SCD CD Player & 192kHz x 24bit DAC
Post by raymond88 Mon Aug 19, 2024 11:41 am
Post by raymond88 Thu Aug 29, 2024 5:59 pm
