Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series"
Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series" Empty Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series"
Post by raymond88 Fri Aug 16, 2024 2:50 pm
Item: Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series"
##BRAND NEW IN BOX##
Retail Price: RM6999
Last Set Clearance Price: RM4199!!!
First Come First Serve
Price: RM4199 or swap/topup
Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series" Velody25
Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series" Velody27
Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series" Velody26
Velodyne DB12
The Velodyne DB12 is part of the new Deep Blue (DB) series Sub Woofer platform development based on Velodyne Acoustics technologies with a modern styling, unmatched performance with a dynamic and accurate output. This Platform is a completely new industrial design, new driver technology and a new Amplifier design.
The new DB Sub Woofer line-up is the predecessor of the successful SPL I series, a very small form factor closed box design.
The completely new rigidly braced MDF closed box design with a front firing woofer for impacting performance without any noise from the cabinet. Due to this small form factor it is easy to integrate into you listening set-up. A high excursion driver with massive dual ferrite magnet and optimised internal motor technology using a 4 layer voice coil for maximum output with extremely low distortion, following the Velodyne Acoustics design principles. Superior bass quality, for a deeper, more accurate bass performance. Line-level and speaker-level inputs let you connect this Sub Woofer to just about any home audio system.
You can use the variable crossover and phase control to fine-tune the sub’s output, so the bass will blend in perfectly with the mids and highs coming from your main speakers, tailor the sub’s low-frequency response to the acoustics of your room.
Key Features
Closed Box Design: Completely new rigidly braced MDF closed box design with a front firing woofer
4 Layer Voice Coil: 4 layer voice coil for maximum output with extremely low distortion
High Excursion Driver: High excursion driver with massive dual ferrite magnet
High Flexibility: Line-level and speaker-level inputs for maximum flexibility
Number of posts : 10430
Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series" Empty Re: Velodyne DB12 Sealed Box 12" Active Subwoofer "Deep Blue Series"
Post by raymond88 Wed Aug 28, 2024 1:47 pm
