Topping Pre 90 Pre Amplifier
Topping Pre 90 Pre Amplifier  Empty Topping Pre 90 Pre Amplifier
Post by dad123my Sun Aug 18, 2024 12:19 pm
Topping Pre90 Preamplifier - Balanced HIFI Preamplifier
- Hi-Res Audio
-NFCA Modules
-Remote Control
-0.5dB/Step Volume Control Relay
-<[url=tel]0.00007[/url]% THD+N
-6-way input selections (with Ext90) 2x RCA + 4x XLR
-145dB Dynamic Range
-<0.3uVrms Noise (actual noise level obtained by boosting the noise of Pre90 by 100 times using a low noise amplifier in front of the APX555B then dividing the measured noise
by 100 times)
- Channel Crosstalk-140dB
Ultra-High Performance NFCA Modules
Pre90 use the similar NFCA module from flagship A90.
Voltage current hybrid feedback architecture along
with UHGF technology provides excellent DC and AC
performance. Ultra-low noise of 0.3uV is miles ahead of
the competition, giving an absurdly high dynamic range of
145dB and no audible noise and darkest background
Fully Balanced Amplifier
Pre90 adopts full balanced structure which can
handle balanced and single-ended signal processing.
The output can be balanced, single-ended signal
processing. The output can be balanced, single-ended,
balanced+single-ended. With the both way of input in
addition to the normal preamplifier usage, Pre90 can be used for "balanced to single-ended or "single-ended to balanced" signal conversion
An Amplifier for Better Audio Signal
With the help of maximum gain +16dB, Pre90s could easily
amplify the weak input signal to acceptable level of next
amplifier. It is worth mentioning that since the noise is as low as 0.3uVrms, this step does not bring in audible noise while amplifying the signal
Relay Volume Control
A large number of high quality Japanese small signal relays are used for volume control of Pre90s. Bring the advantages of precise control, remote control, longevity,
and complete channel balance. If the volume was set high while turn on or switch in, Pre90 will automatically reduced to a safe volume to void your speakers/headphones blown by sudden high volume.
Selectable XLR/RCA Output.
The output of Pre90 could be config to XLR only, RCA
Only or "XLR+RCA". Therefore, the amplifier signal can be connected to two different amplifiers. Moreover when it working with a Ext90, they could provide totally 2*RCA
and 4*XLR stereo inputs. This is enough for multi source
systems.
Safe Volume, No Shocking Sound
The safe volume feature on Pre90 will kick in when the saved volume of the target input or output exceeds the set safe volume, and reduce the output to safe volume,protecting your expensive equipment and your priceless
hearing. The safe volume function can be turned off in the
settings
Price RM Sold
Condition : Like newTopping Pre 90 Pre Amplifier  Img_2018Topping Pre 90 Pre Amplifier  Img_2022
Topping Pre 90 Pre Amplifier  Img_2021
Topping Pre 90 Pre Amplifier  Img_2020
Topping Pre 90 Pre Amplifier  Img_2019
Last edited by dad123my on Sun Aug 18, 2024 5:31 pm; edited 1 time in total (Reason for editing : Sold)
dad123my
Number of posts : 7
Registration date : 2011-01-12
