Cayin MT-35 MK2 Plus (Bluetooth) Vacuum Tube Integrated Amplifier
Item: Cayin MT-35 MK2 Plus (Bluetooth) Vacuum Tube Integrated Amplifier
Condition: 9/10. Item is in LIKE-NEW condition. Full box. Very low usage. Like buying new.
Price:
Pure evacuated tube, pure hand-made, the MT-35 MK2 amplifier adopts point-to-point soldering
Two high quality wide frequency response EI output transformers
Use low-leakage, high-efficiency ring-shaped power transformer specially developed for this machine
A 12AX7 vacuum tube and two 12AU7 vacuum tubes were used for the voltage amplification stage and the push stage respectively.
The power amplification stage uses four EL34 vacuum tubes for AB1 push-pull power amplification
External independent BIAS ADJ. adjustment and BIAS TEST POINT test function to keep the best power vacuum tube at all times
Triodes and superlinearity options are available.
The triode works in a soft, pure and mellow manner. It is suitable for enjoying vocals, strings, and other types of music. Its super-linear working style is open and unrestrained, and it is very good in momentum. It is suitable for enjoying large-scale, large dynamic and other types of music.
With headphone output function
Japanese ALPS high quality potentiometer
Easy to install plug-in vacuum tube protective cover
» Cayin MT-35 MK2 Plus (Bluetooth) Vacuum Tube Integrated Amplifier
» Cayin A-88T Vacuum Tube Integrated amplifier
» Cayin MT-35 MKII Vacuum Tube Integrated Amplifier (PL)
» Cayin MT-45 Vacuum Tube Integrated Amplifier (sold)
» Cayin A-50T Vacuum Tube Integrated Amplifier (Used) SOLD
