Dynaudio Excite X34 Floorstand Speaker, Rosewood, Made in Denmark
Striking floorstander of strong visual and sonic statement
Excite combines high-end sound quality with an elegant, slimline design.
The X34 is extremely amplifier-friendly due to its ultra-linear 8 Ohm impedance, thanks to its flexible design and efficient driver technology.
2x 14cm (5.5″) long-throw mid/bass drivers
1x 28mm Esotec+ coated silk soft dome tweeter
Slimline Excite X34 of 17cm wide, 95cm tall.
Special dispersion character serve up unmistakably high-end sound.
Deep, powerful bass even in spacious rooms
Precise fine-tuning of the crossover optimizes dispersion for incredibly an accurate, three-dimensional presentation of the recording.
Magnetic cloth grille
Foam port plug for adjusting the speaker’s low-frequency performance
Smart base construction of 4x resonance-absorbing feet, 4 adjustable integrated spikes for perfect foundation.
2.5 way Bass reflex rear ported
Frequency Response: 37Hz – 23kHz
Impedance : 8 Ohms
Sensitivity: 86dB
Maximum Amplifier Power: 200W
Designed, engineered and made by Dynaudio Labs in Denmark.
Rosewood dark satin finishing.
Dimension: W170 H900 D260 mm
Weight : 17.0kg each
“For such a relatively lean-looking speaker, I’m surprised by how much punch this packs from its slender profile, and my ears are convinced that the size of the Dyn’s mid/bass drivers are larger than specified.”
“Surprising authority, thick looping piano and bass guitar rhythms..articulate midrange that has all the confidence of a much larger multi-driver three-way speaker.
Integration between the X34’s midband and its top end is of a seamless quality.
Without being overly bright, the treble is clean and crisp, sounds pure and natural.
Impressive sense of scale and energy combined with an even nature.
Powerful and refined sound; great quality finish!” https://www.hifichoicemag.com
“In terms of sonic performance, the X34 isn’t partial to specific genres of music; from country to classical, it’s equally satisfying.
In tonal balance, the X34 is reasonably neutral with the exception of some upper treble shading, and a hint of mid/upper bass ripeness.”
http://www.theabsolutesound.com
“Excite X34 speaker systems showed smooth, organized sound. The dynamics is emotional, without overkill. Bass is well performed and quite deep and powerful. Musical scene is clear and spacious. A neat upper case fills the scene with naturalness and lightness. Timbre resolution is on top. The smallest details are well seen.” http://www.hifi-review.com
RM6,500
Comes with magnetic grille, foam port plug, spikes (No Box)
Used, in good condition.
Welcome for audition @ Subang Jaya ss14
**Credit cards accepted.
Contact 012-611 6917
www.facebook.com/Actsessory/
» Dynaudio Excite X44 Floorstand Speaker Made In Denmark (PL)
» Dynaudio Excite X24 Centre Speaker, Denmark (SOLD)
» Dynaudio - Excite X14 - Rosewood - Bookshelf Speaker (Sold)
» Dynaudio-Excite X34-Floorstand Speaker-(USED)
» Dynaudio Excite X38 Floorstand speaker (SOLD)
