Aragon 4004 MkII - 200Watts Power Amplifier
Aragon 4004 MkII - 200Watts Power Amplifier Empty Aragon 4004 MkII - 200Watts Power Amplifier
Post by raymond88 Fri Sep 13, 2024 3:33 pm
tem: Aragon 4004 MkII - 200Watts Power Amplifier
Condition: Item is in very good working condition.
Price: RM3600 RM3300 or swap/topup
Aragon 4004 MkII - 200Watts Power Amplifier Aragon12
Aragon 4004 MkII - 200Watts Power Amplifier Aragon13
Aragon 4004 MkII - 200Watts Power Amplifier Aragon14
Description
The 4004 is a true dual mono power amp designed by Dan D’Agostino of Krell fame. This will drive almost anything- 200w/ch at 8 ohms, doubling to 400w/ch at 4 ohms- and can drive a 1-ohm load for all unrepentant Electrostatic users out there. Quite a lot of pure Class A watts output before switching into AB. High damping factor resulting in iron grip.
Overbult to a ridiculous specification, it is true dual mono inside with two massive transformers.
The operational condition of this item is excellent, fully tested and no issues found.
Power output: 200 watts per channel into 8Ω (stereo)
Total harmonic distortion: 0.05%
Signal-to-noise ratio: 110dB
Dimensions: 19 x 6.5 x 14.5 inches
Weight: 65lbs/ 29.5kg
Number of posts : 10571
Aragon 4004 MkII - 200Watts Power Amplifier Empty Re: Aragon 4004 MkII - 200Watts Power Amplifier
Post by raymond88 Fri Sep 20, 2024 9:45 am
Post by raymond88 Fri Sep 27, 2024 11:30 am
