KEF Uni-Q Array Q700 Surround Sound Speaker Package 7.1, Rosewood
The critically acclaimed Q Series from KEF has won a vast number of awards and exists to showcase KEF’s design philosophy of reproducing a quality of sound that’s indistinguishable from the actual live event.
The Q Series provides a truly immersive sound response, complete with three dimensional imagery of a richness and clarity normally found in flagship loudspeaker models from lesser brands.
The Uni-Q driver is, top to bottom, a remarkable piece of engineering.
New generation 130mm (5.25in.) and 165mm (6.5in.) Uni-Q driver array respectively, flanked by a low distortion bass unit and an ABR of the same size, they combine raw power with the subtlety to convey moments of great delicacy.
*Class leading sound
*Happy at high, or low volumes
*Easy room integration
*Nicely screwed together
*Look great with the grills off
Uni-Q driver array perfectly captures and replicates dialogue, whether it’s shouted or softly whispered, with incredible precision.
Uni-Q: every seat in the room is sweet spot
Complimented by the duet of 6.5 inch bass driver, much like the human voice to give you the best listening experience.
Z-flex surround on the Uni-Q drivers smooth the transition to the front panel, allowing the Q600c to deliver clean, punchy sound without colorization.
Center of the mid-range cone is the same vented tweeter that gives our flagship Blade speaker its startlingly pure high-frequency response, and our tangerine wave-guide helps disperse high-frequency evenly across a wider angle to fill the room with an intricate and refreshingly natural sound field.
KEF Q700 Floorstanding Speakers:
2.5-way
6.5″ (165mm) aluminium Uni Q with 1-inch (25mm) vented aluminum dome tweeter with “tangerine” waveguide
6.5″ (165mm) aluminium woofer
Dual 6.5″ (165mm) aluminium ABRs (Auxiliary Bass Radiator)
Bi-Wiring capable
Freq response: 36Hz – 40kHz
Sentisivity: 89dB
Impedance : 8 Ohms
Amp Requirements: 15-150W
Dimensions: H920 x W210 x D302 mm
Weight: 17.2kg
KEF Q600C 3-Way Center Speaker:
The big brother, boasting a bigger Uni-Q driver array and duo of bass drivers.
“We’ve designed it so it sounds flawless, no matter what volume you’re listening at.”
-Newly engineered aluminum KEF Uni-Q Driver
-New bass drivers featuring rigid new aluminium cone technology
-30% more cabinet space for increased bass performance
-Newly engineered gold plated bi-wire terminals
6.5 Uni-Q driver array, flanked by two 6.5-inch bass drivers, to fill your home theater with an undistorted and incredibly full sound.
Bi-Wiring capable
Freq Response: 45Hz – 40kHz
Sensitivity : 87dB
Impedance : 8 Ohms
Dimension : H210 x W629 x D302 mm
Weight : 14.10kg
“It identifies different nature sounds with amazing ease and clearly separates them by plans. Vocal transfer is also extremely good. Voices are correctly articulated and tonally clear. Powerful dynamics is conductive to natural imaging of any effects, so the loudspeaker will get next to both small shelf monitors and large floor speaker systems.” -hifi-stereo.net
KEF Q800ds Dipole surround speakers (2 Pairs):
KEF’s Q800ds dipole loudspeaker as your rear or side channels with enhanced performance and realism
3-way dipole loudspeaker
2x 130mm (5.25in.) Uni-Q arrays on each speaker playing out of phase, ambient 3D effects are completely diffused throughout the listening area to create an uncanny illusion of actually being there, whether that’s deep in the rainforest, in a concert arena or driving along a gritty urban back street.
2 x 130mm (5.25in.) aluminium Uni-Q 2 x 25mm (1in.) vented aluminium dome HF
Freq Response: 100Hz – 40kHz
Amp Requirements: 10-100W
Sensitivity: 85dB
Impedance : 8 Ohms
Dimension: H180 x W348 x D180 mm
Weight : 7.4kg
KEF Q400B Subwoofer, Sealed Closed Box, 10″:
The final ingredient of your Q system is of course the seductive Q400b subwoofer.
A closed box design housing a 250mm (10in.) woofer driven by a 200W on-board Class-D amplifier, this discreet cube creates spectacular bass imagery – eloquent, musical and addictively physical. Anchoring the whole sound performance in an all-embracing sensation of immediacy, it completes the acoustic picture.
Its musicality is impeccable: seductively tuneful and well controlled.
Deeper, tighter and more accurate bass.
Featuring rigid new aluminium cone technology like the Uni-Q array, this Q Series advanced bass driver is a tour de force in its own right.
A die-cast aluminium chassis rigidly locates the high efficiency vented magnet assembly to prevent unwanted resonance, large 50mm voice coil ensures impressive power handling.
3-position bass boost (EQ) control allows adjustment of the Q400b’s response to compensate for different room acoustics and personal preference.
Combined with the more usual crossover and volume controls, plus a phase switch, and you have an eminently tuneable subwoofer.
Freq Response: 28 – 140Hz
Max Ouput: 110dB (SPL)
200W Class-D Amplifier
Stereo RCA line level input
Dimension: 335 x 330 x 330 mm
Weight : 13.6kg
Good cosmetic and condition.
No Box.
Comes with grille mesh, spike (floorstand) and power cord (subwoofer)
RM7,500
*Credit cards accepted
Subang Jaya ss14, contact 012 6116917
www.facebook.com/Actsessory
» PMC Surround Speaker Package
» Pioneer S-ES3TB Surround and Center Speaker Package (Sold)
» Yamaha NS-P8900 Center & Surround Speaker Package (SOLD)
» DALI IKON 6 5.1 Surround Speaker Package (Made in Denmark)
» WS-F1 Surround Sound Speaker Stands
