Jamo J10 SUB Subwoofer (Used)
Jamo J10 SUB Subwoofer (Used) Empty Jamo J10 SUB Subwoofer (Used)
Post by choyaudiovisual Tue Oct 01, 2024 2:39 pm
Jamo J10 SUB Subwoofer (Used) 6d0e7410
Jamo J10 SUB Subwoofer (Used) 9c237110
Jamo J10 SUB Subwoofer (Used) 582a0410
Jamo J10 SUB Subwoofer (Used) E03bec10
Jamo J10 SUB Subwoofer (Used) Ad118510
Jamo J10 SUB Subwoofer (Used) 5507cd10
Description
The latest subwoofer line from Jamo offer high value with stylish aesthetics. By utilizing modern materials and core technologies, the J 10 SUB makes your home theater and music listening experiences unforgettable. With an amplifier capable of 300W of peak power, this subwoofer can deliver higher sound-pressure levels at lower distortion, resulting in maximum musical fidelity and reproduction of details.
The J 10 SUB features a 10″ front firing, aluminized polyfiber woofer that provides exceptionally low frequency response with minimal distortion. The all-digital amplifier delivers clean high-efficient power and accuracy in reproduction. Housed in a MDF cabinet with a sleek wood grain vinyl to match our highly acclaimed Studio line, this versatile subwoofer seamlessly integrated into any decor.
Aluminized Polyfiber Woofer Delivers low frequency response with minimal distortion.
All-Digital Amplifier Clean, high-efficient power.
Front-Firing Driver Provides deep bass and placement flexibility.
Low Pass Crossover and Phase Control Allows you to blend the subwoofer’s low-frequency tones and establish the ideal level of bass
Line/LFE Inputs Ensures compatibility with old and new receivers.
MDF Cabinet with Modern Finish Wood grain vinyl provides a contemporary aesthetic.
Front-Mounted LED Power Indicator Lets you know when the system is on or off.
Specification:
Switchable Phase Control:0/180
Weight (Kg/lb):12 / 26.5
Rated output (W): 150W:150W / 300W
Woofer (mm/in): 254 / 10 Aluminized Polyfiber
Frequency Response (Hz, +/-3dB):31Hz – 120Hz
Product dimensions (mm/in, HxWxD) :368.3 x 317.5 x 427 / 14.5 x 12.5 x 16.8
Crossover Frequency:40-120Hz
System Type:Bass Reflex Subwoofer, Front-Firing Driver, Rear Ported
Inputs:Line Level RCA
Price: RM 960.00 inclusive postage to West Malaysia
Number of posts : 5729
