Pro-ject Essential III Phono Turntable (Used)
Pro-ject Essential III Phono Turntable (Used) Empty Pro-ject Essential III Phono Turntable (Used)
Post by choyaudiovisual Wed Oct 02, 2024 8:42 am
Pro-ject Essential III Phono Turntable (Used) Dc328f10
Pro-ject Essential III Phono Turntable (Used) 048d8310
Pro-ject Essential III Phono Turntable (Used) 6a179110
Pro-ject Essential III Phono Turntable (Used) 918df710
Pro-ject Essential III Phono Turntable (Used) 9fa46b10
Pro-ject Essential III Phono Turntable (Used) 6b9c1410
Pro-ject Essential III Phono Turntable (Used) 736d5710
Pro-ject Essential III Phono Turntable (Used) 92d46110
Pro-ject Essential III Phono Turntable (Used) 6fef3d10
Pro-ject Essential III Phono Turntable (Used) Whats144
Description
Essential III Phono is a modern classic that delivers great sound at a very attractive price! Featuring such premium parts as a diamond-cut aluminum drive pulley, a low-resonance MDF plinth & platter and a high-precision main bearing, it delivers lively, highly involving sound that will impress every vinyl lover. Essential III Phono adds a quality MM phono preamp to the already-excellent Essential III base-model – perfect for powered speakers and/or systems that lack a phono input.
Features
Built-in MM phono stage
Belt drive with synchronous motor and silicone belt
Diamond cut aluminium drive pulley
Chassis & platter made of resonance absorbing MDF
Integrated DC-powered motor control minimizes motor vibration and guarantees speed stability
Low tolerance platter bearing with stainless steel spindle
8.6” aluminium tonearm with sapphire bearings
Ortofon OM10 cartridge pre-mounted
High-quality semi-balanced gold-plated Connect it E phono interconnect
Special decoupling feet
Dust cover included
High-gloss colour options: black, red, white
Handmade in Europe
Specification:
Specs
Nominal speeds: 33/45 r.p.m.
Speed variance 33: ±0,70%, 45: ±0,60%
Wow and flutter 33: ±0,21%, 45: ±0,19%
Signal to noise: 66dB
Effective tonearm mass: 8,0g
Effective tonearm length: 8,6″ (218,5mm)
Overhang: 22,0mm
Power consumption: 4,5W
Outboard power supply: 15V/500mA DC, suitable for your country’s mains supply
Phono Section
Gain: 34dB
Output voltage: typically 200mV/1kHz at 5mV/1kHz input
Input impedance: 47kohms/100pF
Noise floor: 68dB
RIAA-equalisation curve accuracy: 20Hz-20kHz / max. 0,5dB
ADDITIONAL INFORMATION:
Weight 5 kg
Dimensions 33.5 × 41.5 × 11.2 cm
Price: RM 1,290.00 inclusive postage to West Malaysia
Number of posts : 5729
