Onkyo TX-NR5010 AV Receiver (Used)
Onkyo TX-NR5010 AV Receiver (Used) Empty Onkyo TX-NR5010 AV Receiver (Used)
Post by choyaudiovisual Sat Oct 05, 2024 10:48 am
Onkyo TX-NR5010 AV Receiver (Used) 0ff34a10
Onkyo TX-NR5010 AV Receiver (Used) 423cac10
Onkyo TX-NR5010 AV Receiver (Used) A5192d10
Onkyo TX-NR5010 AV Receiver (Used) Dd46cf10
Onkyo TX-NR5010 AV Receiver (Used) 8ce35410
Onkyo TX-NR5010 AV Receiver (Used) B9120b10
Onkyo TX-NR5010 AV Receiver (Used) Deae7310
Onkyo TX-NR5010 AV Receiver (Used) Whats173
Description
Onkyo TX-NR5010 was introduced in 2012 and represented a flagship model of a manufacturer. It is equipped with 9 channel amplifier with 145 W (8 Ω, 20 Hz – 20 kHz, 2 channel driven) power per channel and is capable of 11.1 maximum channel processing. It passes 1080/60p and upscales up to 4K/30p (Marvell Qdeo) video signal.
Tuning range: FM, MW
Power output: 145 watts per channel into 6Ω (stereo)
Surround output: 145W (front), 145W (center), 145W (rear)
Frequency response: 5Hz to 100kHz
Total harmonic distortion: 0.05%
Damping factor: 60
Input sensitivity: 2.5mV (MM), 200mV (line)
Signal to noise ratio: 80dB (MM), 110dB (line)
Digital inputs: coaxial, optical
Video Connections: HDMI, component, composite
Dimensions: 435 x 198.5 x 463.5mm
Weight: 25kg
Price: RM 2,900.00 inclusive postage to West Malaysia
Number of posts : 5876
