Fyne Audio F301 Bookshelf Speaker Used
Fyne Audio F301 Bookshelf Speaker Used Empty Fyne Audio F301 Bookshelf Speaker Used
Post by choyaudiovisual Mon Oct 21, 2024 11:45 am
Fyne Audio F301 Bookshelf Speaker Used Slide117
Fyne Audio F301 Bookshelf Speaker Used Slide216
Fyne Audio F301 Bookshelf Speaker Used Slide316
Fyne Audio F301 Bookshelf Speaker Used Slide420
Fyne Audio F301 Bookshelf Speaker Used Slide516
Fyne Audio F301 Bookshelf Speaker Used Slide619
Fyne Audio F301 Bookshelf Speaker Used Slide719
Fyne Audio F301 Bookshelf Speaker Used Slide818
Fyne Audio F301 Bookshelf Speaker Used Image53
Description
Perfect for smaller listening rooms, the F301 is a compact, standmount or bookshelf loudspeaker offering outstanding flexibility and class leading performance. As Hi-Fi stereo pair, the F301 excels at delivering dynamic bass and the musical articulation of more expensive designs. Its high current handling is equally at home in home theatre systems where the F301’s easy to drive nature and deep bass punch are compatible with a wide range of AV amplifiers and receivers.
System Type: 2 way, rear ported
Recommended amplifier power (Watt RMS): 25- 100
Continuous power handling (Watt RMS): 50
Sensitivity (2.83 Volt @ 1m): 89dB
Nominal impedance: 8 Ohm
Frequency response (-6dB typical in room): 44Hz- 28kHz
Drive unit complement: 1 x 150mm multi-fibre bass/ mid 1 x 25mm polyester dome tweeter
Crossover frequency: 3.2kHz
Crossover type: 2nd order low pass, 3rd order high pass
Dimensions – HxWxD: 300 x 190 x 271mm (11.8 x 7.5 x 10.7”)
Net Weight – Each: 5.3kg (11.7lb)
Finishes: Black Ash
Price: RM 1,350.00 inclusive postage to West Malaysia
Number of posts : 5876
