Gryphon Audio Diablo 250 Integrated Amplifier
In good condition 8/10
Made in Denmark
The Gryphon Diablo is a true dual mono design for minimal cross-channel interaction. The monumental, sculpted exterior conceals all the wattage you'll ever need backed up by virtually limitless current capability.
The Gryphon Diablo puts its ample power reserves at your beck and call to vividly re-create the dynamics of a live music event in your own living space. Dynamic variations, the lifeblood of music, convey the ebb and flow of emotion. The Gryphon Diablo takes you straight to the heart of the music. A bottomless source of pure, stable power, the Gryphon Diablo drives any loudspeaker with speed, precision and authority. A relaxed sense of ease, lush elegance and deep musical insight justify once again Gryphon's reputation as the true music lover's audio brand of choice.
True Dual Mono configuration
Zero negative feedback
Microprocessor-controlled 50- step relay volume attenuator for best sonic performance featuring Welwyn ultra-precision resistors
Ultra-short signal path
Minimal internal wiring
Military spec. double-sided up to 105 micron copper printed circuit boards
Dual Mono Holmgren toroidal transformer
PCB-mounted sockets eliminate wiring and shorten signal path
Gold-plated Swiss Neutric XLR sockets for one balanced source
Gold-plated phono sockets with Teflon insulation for 4 inputs and 2 outputs
Fixed-level AV throughput for uncompromising integration with surround preamplifier
Vacuum Fluorescent Display with 2 lines and 50 characters
Adjustable display lighting (High, Medium, Low, Off)
Selling for RM29000
Contact Peter 012-3820333
Whatsapp me https://wa.me/message/DPSIPO7MHBUPA1
Specifications:
2 x 250 W @ 8ohm
2 x 500 W @ 4ohm
2 x 800 W @ 2ohm
Bandwidth (-3 dB): 0.1 Hz - 250 kHz
Power Supply Capacity: 2 x 58.000 microFarad
Gain: +38 dB SUB output gain: + 6 dB
Input Impedance, balanced (20 - 20,000 Hz): 20 k
Input Impedance, single-ended (20 - 20,000 Hz): 8k
Output impedance: 0.019
4 x Single Ended Inputs / 1 x Balanced Input
Total harmonic distortion: 0.1%
Input sensitivity: 563mV (line)
Signal to noise ratio: 88dB (line)
Channel separation: 120dB (line)
Touch Sensitive Front Panel Controls
Weight : 30kg
Dimensions : 48 x 21 x 46cm WxHxD
Made in Denmark
Selling for RM29000
Specifications:
2 x 250 W @ 8ohm
2 x 500 W @ 4ohm
2 x 800 W @ 2ohm
Weight : 30kg
- Number of posts : 2950
» Gryphon Diablo 300 Integrated Amplifier
» Gryphon Diablo Integrated Amplifier
» Gryphon Diablo 300 Integrated Amplifier with Optional DAC
» Gryphon Diablo 300 integrated amp (used)
