PS Audio USA | Class A Gain Cell + Class D ICEPower | GCC-500 Integrated Amp
Contact Number:
WhatsApp Me Directly 用这个直接联系我
Watsap.my/0162893226/
Audition Location 试听地点 (Watsapp PM / Call when arrived | 到达时请 Watsapp 私信或打电话):
Home Sweet Audio, Jalan TKS 2, Taman Kajang Sentral
Class A + Class D Topology! Perfection Design by PS Audio🤩
BEST Sound I Heard from High End Class D Amp SO FAR! High End Sleeper Amp!
NOW ONLY RM 9980!🤯 You CAN HAVE IT on your HIFI RACK!🤩 SHOW IT OFF ~
Retails almost RM20000 (4500 USD$) in Year 2006 (18 Years Ago) ! Partially Handcrafted in USA!
PS Audio的”A类放大+D类放大“设计,完美的结晶!🤩
我听过最好的高端 D 类功放音质!真正的高端隐藏好物!
现在仅需 RM9,980!🤯 让它成为你音响架上的亮点吧!🤩 炫一炫 ~
2006 年(18 年前)零售价接近 RM 20,000(4,500 美元)!部分手工制作于美国!”
Dual Mono Design using B&O ICEpower Output Stage w/ MAX 2000W in 4 ohms (Both Channel)!
PS Audio "Gain Cell" Module Input Stage in Pure Class A Operation
Sleek Display & Blue Lightning as Signature of PS Audio Design
采用 B&O ICEpower 输出级的双单声道设计,4 欧姆时功率高达 2000W(两个通道)!
PS Audio “增益单元”模块输入级,纯 A 类运作
时尚显示屏与蓝色背光,彰显 PS Audio 经典设计风格
The PS Audio GCC-500 is a compelling amplifier for both types of listeners, the eye-closers (ECs) and toe-tappers (TTs). Its dynamic power, especially with the stock GCC-500’s 500 watts per channel, brings out a sense of ease in handling uncompressed musical peaks, ideal for larger rooms and speakers. Its bass control, rich midrange, and detailed treble offer a smooth, non-fatiguing listening experience, similar to tube amplifiers. The GCC-500 keeps complex music coherent and maintains PRAT (pace, rhythm, and timing), allowing individual elements to stand out, from cymbals to vocals. GCC-500 remains impressive, particularly with its extra power for dynamic, toe-tapping music.
PS Audio的GCC-500是一款令人瞩目的放大器,适合两类听众:闭眼倾听者(ECs)和节奏爱好者(TTs)。其动态功率,尤其是原厂GCC-500的每声道500瓦功率,使其在处理非压缩音乐的峰值时表现得非常从容,特别适合大空间和大音箱。GCC-500在低音控制、丰富的中音以及细腻的高音方面表现出色,提供了一种平滑、不易疲劳的聆听体验,类似于电子管放大器。即使是复杂的音乐,GCC-500也能保持清晰和谐,并保持PRAT(节奏、律动和时间感),使个别元素如镲片和人声清晰突出。尤其是在动态的、让人忍不住随之律动的音乐下,GCC-500的额外功率显得尤为出色。
🤩We Provide我们提供:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
CONDITION 品像: = Fully Working 🧾
- Cosmetic: 8.5/10 = Pristine Condition
- Operation: 10/10 = Mint
- Status: 100% RUN IN
SOUND QUALITY REVIEW(音色评测):🤩
- Rock-solid timing and pace across music genres, maintaining clarity with complex music.
- Dynamic ability feels nearly unlimited, with a small edge in ease and power during intense, uncompressed peaks.
- Excellent bass quality—controlled, powerful, and natural in decay—satisfying in both depth and detail.
- Smooth and refined highs that do not emphasize recording flaws; similar to tube amplifiers in their warmth and clarity.
- High-frequency detail brings out individual cymbal textures and allows distinct stick impact, reflecting a nuanced sound.
- Impressive soundstage, with strong lateral imaging and clear layering, although ultimate depth is not on par with some high-end tube amps.
- Low-level resolution reveals delicate musical details, maintaining instrumental clarity without excessive brightness.
- Provides realistic instrument and vocal reproduction; saxophones and other complex tones retain core sound without harshness.
- Strong PRAT (pace, rhythm, and timing), making it a good choice for rhythm-driven or dense music, suitable for long listening sessions without fatigue.
- 在各类音乐风格中展现出稳如磐石的节奏感与精准性,复杂音乐中仍能保持清晰度。
- 动态表现几乎无可挑剔,在激烈、未压缩的峰值中稍具优势,具备出色的轻松感与力量感。
- 低频表现卓越——控制力强、深沉且自然的衰减,深度与细节兼具,令人满足。
- 高频平滑精致,不会突出录音缺陷;音色类似电子管放大器的温暖和清晰。
- 高频细节层次丰富,能够突显出独特的镲片纹理和清晰的鼓棒冲击感,展现细腻音质。
- 声场表现出色,横向成像清晰且层次分明,纵深虽然不如某些高端电子管放大器,但依然优秀。
- 低电平解析力强,能够展现精致的音乐细节,保持乐器清晰度而不过度明亮。
- 能真实还原乐器和人声;复杂音色如萨克斯等在核心音质上保持自然且无刺耳感。
- 优异的PRAT(节奏、韵律与时序),非常适合节奏感强或音符密集的音乐,长时间聆听亦不会产生听觉疲劳。
DESIGN & TECHNOLOGY设计与科技:
- Integrated amplifier with B&O's ICEpower technology.
- Efficient amplifier modules that operate cool, even cooler when active versus idling.
- Equipped with a "Gain Cell" module for managing front-end input with volume and balance control.
- Rock-solid timing and pace across various music genres.
- Consistent clarity for complex musical arrangements, avoiding confusion in detailed passages.
- Offers strong dynamic performance and bass control; distinct sound separation across frequency ranges.
- Smooth treble and high-frequency performance similar to high-quality tube amplifiers.
- Imaging and soundstage are realistic with good lateral imaging and precise front-to-back layering, although depth is slightly behind some premium models.
- Excellent noise control with minimal background haze, allowing detailed low-level resolution.
- Display and power cords influence sound quality slightly; turning off the numeric display can reduce minor treble coarseness.
- 集成放大器采用B&O的ICEpower技术。
- 效率高的放大器模块即使在活动状态下也能保持较低温度,远低于待机时的温度。
- 配备“增益单元”模块,用于管理前端输入,具备音量和平衡控制。
- 在各种音乐类型中展现出稳固的节奏感和时序感。
- 对于复杂的音乐编排保持一致的清晰度,避免在细节段落中产生混乱。
- 动态表现强劲,低音控制出色;在各个频率范围内的声音分离清晰。
- 高频和高音表现平滑,类似于高品质的管式放大器。
- 成像和音场真实,具备良好的横向成像和精确的前后层次感,尽管深度稍微逊色于一些高端型号。
- 噪声控制优秀,背景噪音极小,允许低级别细节的清晰呈现。
- 显示屏和电源线对音质有轻微影响;关闭数字显示可以减少微小的高频粗糙感。
SPECIFICATIONS 规格:🧾
- Configuration: Dual Mono
- Class of Operation: D
- Single-ended Inputs: RCA - 5 pairs
- Balanced Inputs: XLR - 1 pair
- Input Device Type: PS Audio Gain Cell
- Input Impedance: 47.5 kohms
- Input Sensitivity: 8.5V
- Pre-Out: RCA - 1 pair
- Output Binding Posts: PS Audio with Locking Banana Jacks
- Output Power at 8 ohms (GCC-500): 500 Watts
- Output Power at 4 ohms (GCC-500): 1000 Watts
- Gain (RCA): 31 to 41 dB (Adjustable)
- Gain (XLR): 37 to 47 dB (Adjustable)
- Frequency Response (GCC-500): 10Hz - 20kHz (+0.1/-1.0 dB)
- THD (GCC-500 @ 1W): < 0.02%
- THD (GCC-500 @ 500W): < 0.05%
- Power Consumption at idle: < 40 Watts
- Weight (GCC-500): 29.5 lbs.
- Dimensions (W x H x D): 17.25 x 4.00 x 14.00 in.
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
Contact Number:
🤩We Provide我们提供:
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
SPECIFICATIONS 规格:🧾
DISCLAIMER 免责声明:
Last edited by HomeSweetAudio98 on Thu Oct 31, 2024 2:10 am; edited 5 times in total
» PS Audio Stellar Gain Cell DAC (Used preamp) - SOLD
» PS Audio - Stellar Gain Cell DAC + Stellar S300 Power Amp (Sold)
» Hypex and ICEpower class D module sold
» Tube Amp 45W Willsenton R8 Handcrafted High End Class A KT-88 EL34 Tubes Integrated Audio Hifi Audio
» Adcom GCD-575 Class-A CD Player with Variable Output (Sold)
