Musical Fidelity| Class A ECC88/6922 Tubes | X-Pre Tube Preamp & X10-D Tube Buffer w/ X-PSU FullSet
PM Me Directly 直接找我
Music Fidelity "Soda Cans" X Series: Signature Cylindrical Cans Design from MF
X-Pre ECC88/6DJ8/6922 Vacuum Tubes (Pair) Single Ended Triode Tube Preamp
X10-D ECC88/6DJ8/6922 Vacuum Tubes (Pair) Single Ended Triode Tube Buffer
X-PSU PURE Class A Linear Power Supply
Music Fidelity "汽水罐" X 系列:MF 经典的圆筒设计
X-Pre ECC88/6DJ8/6922 真空管(对装)单端三极管电子管前级放大器
X10-D ECC88/6DJ8/6922 真空管(对装)单端三极管电子管缓冲器
X-PSU 纯A类线性电源
NOW ONLY RM 2780 Original PSU Cable from MF!🤯 You CAN HAVE IT on your HIFI RACK!🤩 SHOW IT OFF ~
现在只需 RM 2780 ,含有原装 MF 电源线!🤯 您可以将它放在您的 HIFI 架上!🤩 尽情展示吧~
FULL SET Retails for 发售价 RM6000++!🤯
CONDITION 品像: 8/10 = Excellent Condition|非常好
🤩Can HELP U do 我们可以帮您:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
PERSONAL EXPERIENCE 个人体验: Listen to Believe 耳听为评! 🤩
- Turns HIFI from HASRH & HARD into REFINED & SMOOTH sounding
- IF ur setup is TOO DIGITAL (Digital Amplifier, Solid State Amplifier, Streaming, DACs, CD Players), here u can add some TUBEYNESS
- Suddenly, EVERYTHING sounded SO REAL, NATURAL, ORGANIC & ANALOGUE (LIKE listening to VINYL)
- Soundstage & Imaging SO HOLOGRAPHIC & 3D, when u listen to vocal, the singer is like IN THE ROOM
- U can FELT the SPACE AROUND the INSTRUMENTS & the SINGER
- Notes & Decays STAY LONGER ON THE AIR
- 将 HIFI 从刺耳和生硬的声音变成精致和柔和的声音
- 如果您的音响系统过于数字化(数字功放、固态功放、流媒体播放器、DAC 解码器、CD 播放器),在这里您可以增加一些“电子管味”
- 突然间,所有声音都变得非常真实、自然、有机且模拟(像在听黑胶唱片一样)
- 声场和音像极具立体感和3D效果,聆听人声时,歌手仿佛就在房间里
- 您可以感受到乐器和歌手周围的空间
- 音符和延音在空气中停留得更久
DESIGN & TECHNOLOGY 设计与科技:
Pure Class A
Single Ended Triode
2 * ECC88/6DJ8/6922 Vacuum tubes (Preamp & Tube Buffer)
经典的圆筒设计
纯A类
单端三极管
2 * ECC88/6DJ8/6922 真空管(前级放大器和电子管缓冲器)
SUMMARIZED REVIEWS 评测:
X-PRE
• Warm sound with no brightness
• Soft, pleasant tings and tingles
• Volume knob can be turned up without causing stress
• Revealed shortcomings in the Sansui power amp
• Midrange focus; bass evaluation limited by old amp
• Beautiful rendition of Nat King Cole's songs, with warmth evident in speakers
• Detail not emphasized
• Compatible with good power amps, enhancing smoothness and warmth
• Recommended for classical music listeners, excels with strings and plucked instruments
• Unit remains cool during operation
• 声音温暖,无亮度
• 柔和、愉悦的音色与细微振动
• 音量旋钮可以调高而不会引起压力
• 揭示了 Sansui 功放的缺点
• 中频聚焦;低音表现受老功放的限制
• 对 Nat King Cole 歌曲的美丽演绎,扬声器中充满温暖
• 细节不被突出
• 兼容优质功放,增强平滑感和温暖感
• 推荐给古典音乐爱好者,尤其擅长弦乐和拨弦乐器
• 设备运行时保持凉爽
X10-D
• Musical Fidelity calls the X-10D "the missing link," a "pure Class A Streamer/DAC/CD-player accessory."
• Supposedly, it was marketed to "smooth out" or otherwise enhance the sound of some Streamers/DACs/cd players given over to somewhat "brittle" or "harsh" sound characteristics.
• The unit adds richness, dimensionality, and improves dynamics.
• It takes the sounds of digital —which, straight out of the analog outputs, can be a little thin—and fleshes it out.
• It smooths the treble, adds body to the midrange and bass.
• Musical Fidelity 称 X-10D 为“缺失的环节”,是“纯A类流媒体/DAC/CD播放机配件”。
• 据称,它被推向市场是为了“平滑”或增强一些流媒体/DAC/CD 播放器的音质,这些设备的音质有时会显得有些“脆”或“刺耳”。
• 该设备增加了丰富性、空间感,并改善了动态。
• 它让数字音频的声音——直接通过模拟输出时可能有些单薄——变得更加丰满。
• 它平滑高音,并为中频和低音增加了厚度。
X-PSU
• Instantly the bass response was tightened by several orders of magnitude, the midrange was more warm and clear, and timbre overall improved.
• The noise floor also almost totally gone.
• Performance continues to improve as the unit gets further broken in.
• Things are tighter and more punch.
• Notes decay longer and more natural sound to cymbals and snare drums.
• Vocals are to die for.
• 低音响应瞬间提升了好几个数量级,中频更加温暖清晰,整体音色得到了改善。
• 噪声底噪几乎完全消失。
• 随着设备的进一步磨合,性能持续提升。
• 音质更加紧凑有力。
• 音符的延音更长,铙钹和军鼓的声音更自然。
• 人声表现令人陶醉。
INTRODUCTION 介绍: 🧐
X-PRE
- X-PRE Class A Single Ended
Triode Tube Preamplifier.
- The X-PRE is a true high-end preamplifer
with sound quality equal to the most exotic pre-amps available.
- We
sincerely hope that the X-PRE will bring you many years of outstanding listening pleasure.
- X-PRE 纯A类单端三极管电子管前级放大器。
- X-PRE 是一款真正的高端前级放大器,音质媲美市面上最顶级的前级放大器。
- 我们真诚地希望 X-PRE 能为您带来多年卓越的聆听享受。
X10_D
- Our research over many years has shown that the sound quality
of many CD players can be greatly affected by the type of amplifier
and interconnects used.
- This is because the amplifier and interconnects represent a
variable resistive inductive and capacitive load to the CD players
output stage which adversely affects its performance.
- The X10-D solves this problem by presenting a theoretically
perfect, and perhaps more importantly, absolutely consistent load to
the CD player allowing its output stage to realise its maximum
potential.
- The X10-D, as it were, takes the load off the CD players shoulders and allows it to perform as its designers and manufacturers
originally intended.
- 我们多年来的研究表明,许多 CD 播放器的音质会受到所用放大器和连接线类型的极大影响。
- 这是因为放大器和连接线对 CD 播放器的输出级呈现出可变的电阻、电感和电容负载,从而不利于其性能表现。
- X10-D 通过为 CD 播放器提供一个理论上完美的、更重要的是绝对一致的负载,解决了这一问题,使其输出级能够发挥最大潜力。
- 可以说,X10-D 减轻了 CD 播放器的负担,让其能够按照设计者和制造商的初衷表现其最佳性能。
X-PSU
- The X-PSU upgrades and powers up to four X-Series units.
- We hope that by further improving the performance of your X Series components the X-PSU will bring you many years of listening
pleasure.
- X-PSU 可以升级并为多达四台 X 系列设备供电。
- 我们希望通过进一步提升您的 X 系列组件的性能,X-PSU 能为您带来多年的聆听享受。
SPECIFICATIONS 规格:🧾
X-PRE
- Inputs: 4 Line level
- Total Harmonic Distortion (THD):
- < 0.007% 20Hz-20kHz unweighted
- < 0.005% 20Hz-20kHz ‘A’ weighted
- Frequency Response: +0.3dB 20Hz-20kHz
- Crosstalk: > 63dB separation
- Signal-to-Noise Ratio (S/N ratio):
- 78dB unweighted
- 88dB ‘A’ weighted
- Valve type: 2 x ECC88
- Power Requirement: 12V AC 500mA (via mains adaptor supplied)
- Dimensions (mm): 110 x 110 x 220 (W x H x D) [Width and height include feet]
X10-D
- Input impedance: 470 KOhms
- Output impedance: < 200 Ohms
- Total Harmonic Distortion (T.H.D.): < 0.005% from 10Hz to 100KHz
- Frequency response: +/- 0.2dB from 10Hz to 100KHz
- Crosstalk: better than -85dB from 20Hz to 20KHz
- Signal-to-Noise (S/N) ratio: better than -98dB (unweighted), better than -112dB ('A' weighted)
- Power requirement: 12V AC, 500mA (via mains adaptor supplied)
- Dimensions (mm): 110 x 110 x 220 (Width x Height x Depth) including feet.
X-PSU
- Output: Four outputs at 12V AC 20VA each
- Power requirement: 100/115/230V AC 50/60Hz
- Factory preset
- Power consumption: 60W
- Standard accessories: IEC mains lead, - Set of four X-Series power leads
- Width and height include feet
REFERENCES 根据:🫡:
1. https://www.musicalfidelity.com/uploads/manuals/English/xpre.pdf
2. https://www.musicalfidelity.com/uploads/manuals/English/x10d.pdf
3. https://www.musicalfidelity.com/uploads/manuals/English/xpsu.pdf
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
X-PSU 纯A类线性电源
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
- 您可以感受到乐器和歌手周围的空间
- 音符和延音在空气中停留得更久
Pure Class A
Single Ended Triode
经典的圆筒设计
纯A类
单端三极管
X-PRE
• 声音温暖,无亮度
• 柔和、愉悦的音色与细微振动
• 音量旋钮可以调高而不会引起压力
• 揭示了 Sansui 功放的缺点
• 中频聚焦;低音表现受老功放的限制
• 细节不被突出
• 兼容优质功放,增强平滑感和温暖感
• 设备运行时保持凉爽
X10-D
X-PSU
• 噪声底噪几乎完全消失。
• 音质更加紧凑有力。
• 人声表现令人陶醉。
INTRODUCTION 介绍: 🧐
X-PRE
- We
X10_D
potential.
X-PSU
pleasure.
SPECIFICATIONS 规格:🧾
X-PRE
- 78dB unweighted
- 88dB ‘A’ weighted
X10-D
X-PSU
- Factory preset
REFERENCES 根据:🫡:
DISCLAIMER 免责声明:
» Musical Fidelity X10-D Tube Buffer
» Musical Fidelity X10-D Tube Buffer (Used)
» Musical Fidelity tube buffer (used) SOLD
» Musical Fidelity X-10 V3 Tube Buffer (SOLD)
