Yamaha | White Paper Cone | Acoustic Suspension | MP Caps | NS-10M Bookshelf Speaker w/ Grilles
PM Me Directly 直接找我
EVERYTHING IS ORIGINAL, even the MANUAL PAGE & BINDING POST at the BACK is STILL THERE !!
🤩AMAZED by its capability of Vocal & Instruments Representation, Sounds so True & Natural, NO MSG!
所有一切都是原装的,甚至连手册页和背后的装订柱都还在!!
🤩对它的声音和乐器表现能力感到惊叹,声音真实自然,没有任何“添加剂”!
Pure Craftmanship by Yamaha in Japan!
Conical White Paper Midbass Driver w/ Ferrite Magnet & Copper Ribbon Wire Voice Coil
Soft Dome Tweeter w/ Ferrite Magnet & Copper Clad Aluminum Wire Voice Coil
Crossover w/ MP Capacitor
由日本雅马哈纯手工打造!
锥形白纸中低音驱动单元,配有铁氧体磁铁和铜带线音圈
软球顶高音扬声器,配有铁氧体磁铁和铜包铝线音圈
带MP电容的分频器
NOW ONLY RM 1980 w/ Original Grilles!🤯 You CAN HAVE IT on your HIFI Speaker Stand!🤩 SHOW IT OFF ~
现在只需 RM 1980 (有原装网罩)🤯! 你就可以拥有它,放在你的音响脚架上🤩!炫一炫它〜
CONDITION 品像: 8/10 = Great Condition
🤩We Provide我们提供:
HiFi Tweaking 调音
🤩Deal Method 交易方式选择:
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
Analog Cables 类比线 (RCA & XLR)
Power Cord & Cables 电源线
SOUND QUALITY REVIEW(音色评测):🤩
- Yamaha NS-10M is renowned for its accuracy and transparency, making it a staple in professional studios worldwide.
- Its sound signature is known for its detailed midrange and clear highs, offering an uncolored representation of audio.
- The speaker's design emphasizes accuracy over artificial enhancements, providing a faithful reproduction of the original sound.
- The NS-10M's midrange clarity is particularly impressive, allowing for precise vocal and instrumental reproduction.
- Despite its relatively small size, the speaker delivers a surprisingly robust and well-defined bass response.
- Its neutral sound profile makes it suitable for critical listening, enabling users to discern subtle nuances in recordings.
- The NS-10M's durability and reliability have made it a trusted choice for audio professionals and enthusiasts alike.
- While not designed specifically for hi-fi listening, its accuracy and transparency make it well-suited for audiophiles seeking a faithful reproduction of recorded music.
- Yamaha NS-10M以其准确性和透明度而闻名,使其成为全球专业录音室的标配。
- 其声音特性以细腻的中频和清晰的高频著称,提供未经过修饰的音频表现。
- 这款音箱的设计注重准确性而非人工修饰,能够真实还原原始声音。
- NS-10M在中频方面的清晰度尤为出色,可精确再现人声和乐器的声音。
- 尽管体积相对较小,该音箱却能提供令人惊讶的强劲且清晰的低频响应。
- 它的中性声音特性非常适合批判性聆听,使用户能够辨别录音中的微小细节。
- NS-10M的耐用性和可靠性使其成为音频专业人士和发烧友的可信赖选择。
- 虽然它并非专为高保真聆听设计,但其准确性和透明度使其非常适合那些追求真实音乐再现的音响发烧友。
DESIGN & TECHNOLOGY 设计与科技:
-Nicknamed "Big Ben," used globally as a studio monitor, with over 300,000 units sold.
-Features an 18 cm cone type woofer for low range, utilizing a conical white straight cone diaphragm manufactured with a sheet method to minimize density and thickness irregularities.
-Woofer incorporates a flexible, high-compliance roll edge for long-term stability, with a ferrite magnet circuit achieving a magnetic flux density of 10,800 Gauss.
-Woofer's voice coil utilizes edgewise winding of heat-resistant copper ribbon wire, coupled with a lightweight bobbin for high efficiency and input resistance.
-Utilizes a 3.5 cm soft dome type tweeter for high range, employing a soft dome diaphragm integrally
molded with tangential edges.
-Tweeter's magnetic circuit includes a 14,000 Gauss ferrite magnet, a 27 mm φ voice coil made of heat-resistant copper-clad aluminum wire, and a lightweight craft bobbin for high input resistance and efficiency.
-Network section equipped with an MP capacitor for enhanced sound quality.
-Enclosure features a sealed system with a six-sided integrated structure using 12-15 mm thick particle board bonded with strong adhesive.
-Sealed air suspension controls cone paper movement and reduces mechanical resistance at the edge.
-Filling material selected for interior based on sound perception.
-Exterior finished with black paint using real wood.
- 被昵称为“Big Ben”,在全球范围内作为录音室监听音箱使用,销量超过30万台。
- 配备一个18厘米锥形低音单元,采用白色锥形纸盆,通过片状工艺制造以减少密度和厚度的不均匀性。
- 低音单元具有柔软且高顺性的滚边,以确保长期稳定性,采用10,800高斯磁通密度的铁氧体磁路。
- 低音单元的音圈采用耐热铜带线边绕法,并配备轻量的音圈骨架,提高效率和输入耐受性。
- 配备一个3.5厘米软球顶高音单元,使用带切向边缘一体成型的软球顶振膜。
- 高音单元的磁路包含14,000高斯的铁氧体磁铁,27毫米直径的音圈使用耐热的铜包铝线,并配备轻质的音圈骨架,以提高输入耐受性和效率。
- 分频网络部分配有MP电容器,以增强音质。
- 音箱采用密封系统,六面一体结构,使用12-15毫米厚的刨花板并用强力胶粘合。
- 密封空气悬挂系统控制纸盆运动,减少边缘的机械阻力。
- 内部填充材料基于声音感知选定。
- 外观使用黑色涂漆,配有实木饰面。
SPECIFICATIONS 规格:🧾
- Method: 2-Way, 2-Speaker, Airtight Type, Bookshelf Type
- Low Band Unit: 18 cm cone type
- High-Pass Unit: 3.5 cm dome type
- Playback Frequency Band: 60 Hz to 20 kHz
- Crossover Frequency: 2 kHz, 12 dB/oct.
- Impedance: 8 Ω
- Output Sound Pressure Level: 90 dB/W/m
- Rated Input: 25 W
- Max Input: 50 W
- External Dimensions: Width 215 mm x Height 382 mm x Depth 199 mm
- Weight: 6 kg
REFERENCES 根据:🫡
1. https://www.retrosonicproaudio.com/product/yamaha-ns10m-studio-monitor-pair
2. https://lofimusic.com.au/products/yamaha-ns-10m-pair-classic-studio-monitor-speakers-matched-pair-with-grilles
DISCLAIMER 免责声明:
2. 购买后不退货/不退款(允许以商定的价格以旧换新)。
PM Me Directly 直接找我
由日本雅马哈纯手工打造!
带MP电容的分频器
🤩We Provide我们提供:
HiFi Tweaking 调音
Speaker 喇叭
CD Player 光盘播放器
Turntable 唱盘
Streamer 串流机
- 内部填充材料基于声音感知选定。
- 外观使用黑色涂漆,配有实木饰面。
SPECIFICATIONS 规格:🧾
- Impedance: 8 Ω
- Rated Input: 25 W
- Max Input: 50 W
- Weight: 6 kg
REFERENCES 根据:🫡
DISCLAIMER 免责声明:
» SOLD Q acoustic 3010i bookshelf speaker white (USED)
» Pro-Energy Hi-Fi 3 way Paper Cone Driver 10 inch Bass Woofer Local Selfmade Floorstand Speaker
» AmpOhm Paper in Oil, Tin Foil caps
» BOSE Series IV USA | Direct/Reflecting® Technology | x9 4.5" Paper Drivers 901 Bookshelf Speaker
» JBL USA 1st Batch 4312 Control Monitor in Rosewood | Coated Paper Drivers | 3 way Bookshelf Speaker
